hello, I changed the mileage of my saab 95 of 2008 but now I receive an error message.
and when I drive the car with the mileage remains the same.
where is a problem?
thank you very much
where is a problem?
thank you very much
check that you have no excess solder on the board
what did you use to change the mileage might have written to wrong address, dump the saved file which i hope you did and just start again.
you can return orig. file and look now
that is to say?
that is to say?
thank you
Here is the original file, can I change it has 172000 km please?
saab 95 AM 2008
Thank you very much
SAAB.rar
thank you very much
172,000 original miles which
no original is 370696 KM
THANK YOU
my friend, the dump hasn't been read fine, you have to read it in 16 bit as you have been advised by drpeter here : http://www.digital-kaos.co.uk/forums...please-247848/
if you lost the original dump, then explain your new problem, maybe someone can share a reliable dump for you or even can advise you with a better solution.
good luck!
<< KEEP LEARNING W.O LIMITS >>
2 Simple Methods To Say Thanks on DKPress Thanks _OR_ Add Rep
