Results 1 to 15 of 16
Thread: 3.4e version
    Mar 2011
    Default 3.4e version
    hi all my consloe is runing on the 3.4e how do i upgrade, it has been flashed ( watever that been done to it) will this affect in anyway or will it still be possible to use the old games & play the newer one's?? thanks
    V.I.P. Member ck-ok's Avatar
    nottingham
    Quote Originally Posted by localhero View Post
    if it were me i'd update homebrew channel then update to 4.3 then mod it with http://www.digital-kaos.co.uk/forums...indows-170234/
    Mar 2011
    thanks gonna give it go now!!! let you kno how i got on..
    Mar 2011
    S. downloaded 4.3.4 unzipped now what???
    nottingham
    run the program, update it, answer a few simple questions and let it download all your files and a custom tutorial.
    Mar 2011
    theirs nothing to run?? S.. complete newbie.. i have installed homebrew on wii but all i get is the bubbles. bootmi wouldnt load, tried both bootmi????
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    Well this is what I would do.
    If you have a 3.4E I would let it do the online update to 4.3E which is the last Wii version number. Then you can use LetterBomb then you won't need to buy\borrow any original games discs.
    This will softmod your Wii only. You would then need to backup your NAND (first very important job you MUST do there are tutorials on here), install PriiLoader 0.7 to block any online or disc updates. Then choose which USB Loader you want use, I recommend USB Loader GX there are tutorials on here.
    Oh you need a large suitable mains powered HDD to stick all your games on, job done.
    Keith
    2010 Golf GTD (170)
    Aug 2010
    England
    You have bubbles showing because either don't have an SD card inserted or you have no programmes in the app folder.
    So you've softmodded your Wii now?
    As I've just said You would then need to backup your NAND
    BootMii won't load because you have softmodded correctly. You should do all three options when you softmodded.
    1. Install Homebrew.
    2. Install BootMii on Boot 2 or IOS if you have a 4.3
    3. Prepare SD card this puts the [bootmii] folder on the SD card so you can run BootMii from HBC.
    Keith
    2010 Golf GTD (170)
    Mar 2011
    thanxs.. so i update the wii via the wii update its self?
    Mar 2011
    keith.. i put homebrew browser into the apps folder but still nothing!! im using md card in an adapter! but i havnt updated to 4.3 via the wii itself.. nand??
    Aug 2010
    England
    You just said you've softmodded your Wii?
    If you are going for 4.3E then you click on the update button in Wii Settings.
    If you update to 4.3E now you will have to softmod again.
    Just hang on a bit and see what other users suggest?
    Keith
    2010 Golf GTD (170)
    Mar 2011
    just no browser options when on the hbb screen!
  13. #13
    Aug 2010
    England
    When you softmodded did you do all three options?
    So if it softmodded with the MD card and adaptor inserted the files must have been read else an error would have shown.
    If you only see the bubbles when you choose Homebrew from the Wii menu as I said it because it can't find the SD card. While the bubbles are showing I think its button 1 or 2 shows and option where to search for devices to run.
    Get yourself and proper size 2GB SD card they are cheap enough.
    I assume you formatted the MD card FAT32?
    If you press the Home key when the bubbles are showing you will see the BootMii option.
    Keith
    2010 Golf GTD (170)
  14. #14
    Mar 2011
    rite tried again got bootmii loaded, clicked the home launched bootmii, the screen has several options ( in a sd card appearance) i have to use the power button & reset button on the wii to move & accept the icon as the controller doesnt work on this option??? have i got it rite so far(x) if so wats the nxt step cheers..S
  15. #15
    nottingham
    try this post for more info on nand backups http://www.digital-kaos.co.uk/forums...loader-109168/
