This free tool supports a limited range of MEP's but many of you will still find it useful. If this tool does not support your phone (i.e. MEP not found) then you'll need to post a request in the Blackberry unlock code section once it is up and running again!
Note: Unless you have at least one valid forum post you can not download the file!
If you already have your MEP and IMEI then jump to Step 8/9 and enter the IMEI manually and select the MEP from the drop down menu.
1. Install Blackberry Desktop manager. If you don't have it visit:
Cell Phones, Smartphones & Mobile Phones from BlackBerry.com you'll find it there!
2. Download the unlocker:
Digital Kaos - Downloads - BlackBerry Unlocker
2a. Newer version can be found here: http://www.digital-kaos.co.uk/forums...ml#post1499582 no password for this version!! <<<--- NEW <<<---
3. Un-RAR the file using the
Password: fromdigitalkaos
4. Just copy the files into a directory (folder) of your choice.
5. Run the program BlackBerryTools_2.exe
6. Connect handset, wait for drivers to load and then click MEP Reader (
1).
7. Then click on MEPReader button (
2).
8. Now click on Blackberry Tab (
3). Check MEP and IMEI are correct - If not enter the correct details.
9. Then click on Calculate (
4).
10. To find out how to enter your code click on MEP Reader Tab (
5) and then on HOW TO button (
6).
11. Follow the instructions given for your handset.
Please do not attempt to post comments in this thread as it should be self-explanatory. If you can not follow these instructions the do not use the software.
