Found this elsewhere, its beta and dont know if its clone safe.
not tried it as mrs watching soap shite and then im watching footy
edit:
also find attached s9 beta firmware
edit:
Is this firmware offical
Anonymous fw is clone safe.
Fixed by anonymouSX 5 jan 2012
fixed Timebomb kill clone
Id detection fixed
Reboot probleme fixed
cc**m lag freeze Fixed
Standby Freeze issue Fixed
Power on Message on Display Changed
If it isn't broke, don't try fixin it..!!!
Thank you....
I am running the s10 fw above on my original box, comes ready set up with euro sats, start up background now says skybox.. so far so good![]()
thank you you are great
I tried this on my s11 and found the front display issues has been resolved but randomly my remote locked, maybe its a s11???
why not making a better and bigger (using usb) and more quality firmware if the code is hacked. 4mb firmware cann't be as good as dreamboxes one.
this thing has enough ram, if i'm not wrong 1g and 400mhz cpu and I guess with using USB port and a flash memory, a team could make a better firmware like for other linux receivers
Where can one get a user manual of skybox S11
Use search or google functions
mb you have clone?
that's what I have:
Specification
*Chipset and Memory:
CPU: 396MHz
Flash: 4Mbytes
RAM: DDR2-1Gbit
and the firmware is 4mb, where is the half?
also I guess it doesn't metter if it's linux or not currently, on those cpu you can find linux receivers too, so I guess it's solved, why not to support the idea? it will only make this receiver better
page 3 of the users manual says 128mb ddr400 ram.
not a clone.
the sdram.ini file of the rs232 loader is set for 128mb ram.
1/2 the flash is code,the other 1/2 is FF's so only 1/2 is being used.A moot point since most code is usually transferred and runs from ram anyway.
