Results 1 to 15 of 56
Hybrid View
    Jan 2012
    Quote Originally Posted by slugworth View Post
    If you look at the .abs you will see they are only using about 1/2 the flash now.
    The receiver isn't linux,it uses ali tds2 rtos
    Mainboard: 396MHz MIPS CPU, 128MB DDR400 RAM, Memory Clock 198Mhz, 4MB Serial Flash, Single Tuner, DVB-S2 demodulator
    mb you have clone?
    that's what I have:
    Specification
    *Chipset and Memory:
    CPU: 396MHz
    Flash: 4Mbytes
    RAM: DDR2-1Gbit
    and the firmware is 4mb, where is the half?
    also I guess it doesn't metter if it's linux or not currently, on those cpu you can find linux receivers too, so I guess it's solved, why not to support the idea? it will only make this receiver better
    DK Veteran slugworth's Avatar
    Nov 2011
    new england
    Post org
    Quote Originally Posted by mrfarnhigh View Post
    mb you have clone?
    that's what I have:
    Specification
    CPU: 396MHz
    Flash: 4Mbytes
    RAM: DDR2-1Gbit
    also I guess it doesn't matter if it's linux or not currently, on those cpu you can find linux receivers too, so I guess it's solved, why not to support the idea? it will only make this receiver better
    page 3 of the users manual says 128mb ddr400 ram.
    not a clone.
    the sdram.ini file of the rs232 loader is set for 128mb ram.
    1/2 the flash is code,the other 1/2 is FF's so only 1/2 is being used.A moot point since most code is usually transferred and runs from ram anyway.
    Jun 2012
    Default How to tell if receiver is original or clone.
    I'm seeing a number of Openbox receivers on Ebay. How do you know if they will be original or clones?
