Results 1 to 13 of 13
    spiridonas's Avatar
    Default DAEWOO MATIZ Blocked by Immobilizer
    Hi guys when connect the diagnostic tool (kts640) to DAEWOO MATIZ says fault: Blocked by Immobilizer
    uploaded two dumps from ecu 29f200 and from immo 93LC56.
    Please i need to remove this fault will start the car.
    Many thanks in advance.
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    Make key using SBB or T300 via OBD2.
    spiridonas's Avatar
    Hi i don't have SBB or T300 can you modify the dump to start the car or can you make immo off.
    Many thanks.
    lupu_sandu's Avatar
    Far far away
    No immo off AFAIK m8.
    vanos batam's Avatar
    Batam-Indonesia
    Quote Originally Posted by spiridonas View Post
    ID48 - JMA TP08 - SILCA T6
    Daewoo/Chevrolet
    The transponder is locked!
    UP: 12498779
    _______________ D3-oToprog _________________
    ig : vanos_batam
    spiridonas's Avatar
    Quote Originally Posted by vanos batam View Post
    Daewoo/Chevrolet
    UP: 12498779
    with this dump can start the car?
    Batam-Indonesia
    Default or
    try above dump...
    write to ID48
    ig : vanos_batam
    Jun 2009
    if the ecu has blocked by immo you should not diagnose to ecu .
    remove from a working car immo and key put it on your car and make diagnose .
    after that you can use sbb ot t300 to program keys on your immobox .
    the best away is to use a emulator and collect your money
    spiridonas's Avatar
    I tried with Daewoo emulator and remove immo box but car not start.
    igorr's Avatar
    Aug 2010
    I have had same problem and solution is to reset ecu and program keys.I did that vith mvp clone
    Jan 2012
    i have same problem with audi a3 . don't know how to reset ecu.
    Good luck.
    Jun 2009
    the chinese emulator not works .only from immolab
  13. #13
    DK Veteran carmansk's Avatar
    Oct 2010
    World globe
    Exclamation
    Quote Originally Posted by gadroulll View Post
    yes you are right china is ****ing emulator !!!!!!!!!! ****ing china clone!
