    Harrycz44
    Guest
    Default BDM with SID803A
    Hello
    I want read siemens SID 803A with BDM but I do not have adapter and must connect wires.. Do you know anybody how connect BDM to SID803A ?? Thank you
    Quote Originally Posted by Harrycz44 View Post
    Hello
    Use the attached pic and find the SIEMENS adapter layout, is posted od DK... use SEARCH... and you are done!
    micromax's Avatar
    South Poland
    on this site BDM-Instruktion - OBD-Wiki you have all possible connection.
    Harrycz44
    Guest
    Quote Originally Posted by micromax View Post
    There is only BDM adapter and pin 1. But I need connect only wires from bdm to ecu
    Try these
    DO NOT POWER the BDM-interface itselfe with 12v-external
    powersupply !!! (i was told)
    I didn't succeed with my sid803A, but they are known to be fragile.
    Please let us know if you have succeeded, and make us some screenshots please
    Cheers,
    PvL
    Jun 2019
    Default Volvo V50
    I have replaced engine from Volvo V50 2006 to my V50 2007.
    Older one was using SID803 and newer one SID803A.
    Now I need to switch off dpf in SID803A as older one didnt have it.
    Quote Originally Posted by pvl View Post
    Try these
    Cheers,
    PvL
