Results 1 to 8 of 8
    Default Passat AFS problem
    Hello
    I have a The system does not recognize AFS right module, what is strange both lamps are recognized as left (i connected each seperately)
    My question is,how does J745 module recognize which lamp is left and which one is right?. Both have coding 00000035
    Liteace's Avatar
    Mar 2009
    On a rock
    Have you done an auto scan, any fault codes ?
    I make diagnostics with VCDS
    5 fault codes stored of faultly AFS left and right modules, wrong coding, wrong basic settings.....now i dont know exactly.
    I can`t make coding
    Propably right xenon module was replaced because it`s a ceashed car.
    CAN and wirings ok
    Whats the auto scan function?
    Liteace's Avatar
    Mar 2009
    On a rock
    This:
    do a autoscan and post results here
    ok
    The problem is that the master module didnt see the right xenon module... dont know why.....
    Part numbers of xenon modules are ok:
    left 7L6 941 329 SW X018
    right 7L6 941 330 SW X018
    Liteace's Avatar
    Mar 2009
    On a rock
    Quote Originally Posted by misiekgol2 View Post
    ok
    What year and model is it. What fault code have you got ?
    Passat 2007
    Sorry but I will check fault codes tomorrow
    Problem solved
    Solution:
    Wrong right xenon module (wrong part number)
    Wrong AFS module coding
    Best regards
