kugglefischer (2nd December, 2013)
For IAW5NR2 - here's info http://www.digital-kaos.co.uk/forums...tml#post900066
For IAW5NR (hybrid) - here's info http://www.digital-kaos.co.uk/forums...ml#post1334255
Ever wonder how is look like Magneti Marelli 5NR2 C5 on the back side?
Look to the picture below.
It has a bga Motorola MCU withe the following markings:
SC505709BMZP33
8J28H
QQGN0217A
...and ALOT of testpoints.
After some research i find out, according with the mask (8J28H) the mcu is Motorola MC68F375BGMZP33 (see attachment for datasheet).
Pretty advanced toy huh?
Someone tested is this solution working for ECU 5NR2.C2?
I cut the +12v and connected with +12v IGN on ecu side and reprogram epprom 95160 and car doesnt start with just blade even first time. For me its doesnt work. When I put transponder back car starting. IMMO still working.
What is the 100% working solution for this ECU?
IMMO line have to be cut also? In my case is still working!
Car is Clio 2002 1.2 16v
fenix5 (29th December, 2013)
pass pls bro
Anyone can help me to make IMMO OFF on this ECU.
IAW 5NR2.T3.
In attachment the dump from the 95160.
It's not Hybrid ECU.
Thanks in advance.
I have try IMMOkiller but not working (with L4 cut and jump from L4 to H4.
ktome (5th November, 2023)
Any Emulator working with this ECU?
swap +30 to +15 work fine on this
on a rich or poor discussion - PL & SP blood - only on bench
I haven't understand what need to swap.
Try this !
Diagnostique Auto Algerie
Immotool 1.4 By T-E for PSA and many more ...
EDC17 VAG/PSA/FIAT/ALFA/LANCIA IMMO OFF IS NOW POSSIBLE
ampibali (5th October, 2022), aroo84 (2nd June, 2015), brodaty (14th July, 2017), BusCan (6th January, 2020), didi_du_93000 (27th December, 2013), illestibor (13th June, 2023), javiercj (8th August, 2016), k1champion (28th December, 2017), pbn (11th February, 2016), picoche (27th August, 2016), redash (15th January, 2020), roberto033 (7th May, 2019), Tanjona (14th January, 2022), vavrich (13th December, 2023), yanni8 (7th March, 2014)
Thanks Amine,
What need to do? just write this dump inside eeprom without WP acitve?
Or need to put WP?
Need to cut any pin?
Thanks a lot Amine,
Your dump full working!!!
CAn anyone do me immo off, and what wires i need to cut exacly!
and Thank you V much!
renault clio
Hi can I have the pass please?
Am1n-0snşifre alabilirmiyim
