Results 1 to 3 of 3
    Jan 2012
    Default Cannot install any Cam on my DM500HD
    Hello there, I have gone through all webpages and tutorials to manually install cccam and MGcam on The Gemini2 Project 5.1 DM500HD Enigma 2.. I placed the .tar.gz file of the mgcam downloaded from Gemini Images free Gemini Images, download Gemini Images, Gemini Images free download and installed from the file manager and the installation supposedly gone successful, but when i ftp using DCC i couldnt fine the files of the cams to configure, as if it was incorrect version or the package was installed in a wrong place!!! what can i do? I deleted the configurations from addons and re-installed ,,, what else can i do?? re-install the image??? or should i change the Gemini image?? which image other than gemini can be installed on DM500HD?? which is the best?
    Nov 2011
    I use openpli 2.1 on my dm 500hd ( not a clone ) and works a treat and has cccam on it and has lots of plugins you can download a handy one is crossepg gives you a 7 day egp on nearly all channels handy if you have a hard drive installed for recording.
    Jan 2011
    North West England
    Is the set up the same a dm500s? Same set up as in you can use the same image and cccam conf file to enter c and F?
