Results 1 to 8 of 8
    Dec 2011
    east Europe
    Default Help on opel combo
    greetings all I have a problem with a 2007 Opel Combo Z13 DTJ can not get rid of the error P1901 something about FAP regeneration. I have therefore a question for those more experienced. can use ECUSAFE to eliminate DPF? what interface to reed the ECU ?what ECU to select EDC17 or mareli MJD? I have galeto and KVP ,do I need MPPS to reed on can protocol or can use what Ihave and reed on K line.Thank you in advance
    It's a problem with the differential pressure sensor.
    Probably a worn/cracked pipe, maybe a defective sensor.
    Dec 2011
    east Europe
    unfortunately not I ,changed the sensor try to make regeneration everything is proceeding normally finally said perform ok but Light on dash turn on and error P1901 reed-it with delphi tester
    What pressure do you read in live data?
    Dec 2011
    east Europe
    I didn't check I will check tomorrow and I will return, but do not know if Delphi can see the value KTS 1 \ 2011 not shown. anyway thanks for response I will return tomorrow. You mean the percentage of regeneration?
    No, I mean the value from the sensor you replaced.
    Although any value (either from a sensor or calculated) regarding the DPF is interesting.
    If you are reading with an EOBD scanner you can't see these values. Op-com is a good choice for Opel/Vauxhall.
    Dec 2011
    east Europe
    thank's @ oldford I will tray with OP-COM and report.
    se poate deprograma dpf-ul.
    de unde esti?
