Results 1 to 14 of 14
Hybrid View
    Feb 2011
    Almeria, Spain
    Default HOW TO DESOLDER EEPROM, WHERE WHEN NOT MELT WELDING AND DAMAGE THE EEPROM OF GRAPHITE
    Hello friends
    you happened to try to remove the welding of an eeprom of 8 pins of an airbag unit circuit, there is no way to remove the Tin.
    I have done many and micros motorolla etc.
    Remove welding with station, hot air and without any problem.
    Therefore well today has gone.
    was a unit of airbag and the eeprom circuit there is no way to desolder. to the finao graphite from the eeprom has burned and not
    has desolder
    there is any product that does not happen more, avoid damaging the circuit and not burn the eeprom memory, and allows desolder.
    hope answer
    circuit came with a kind of enamel even so there is no way
    help please
    ovi_dk's Avatar
    On board
    Tell the type of module maybe sombode can give u the pinout.
    B.R
    If u have the answer say Thank You!!
    Feb 2011
    Almeria, Spain
    Quote Originally Posted by ovi_dk View Post
    B.R
    Hello
    thank you for answering the switchboard of airbag;
    autoliv
    550-80-44-00 //8200 018 830
    eeprom is 93c66
    thanks I hope answer
    Youneselm's Avatar
    Nov 2010
    you can desolder it with hot air
    Feb 2011
    Almeria, Spain
    Quote Originally Posted by youneselmoukhtari View Post
    hello youneselmoukhtari
    thanks for your resquest
    i am desoder with hot air
    you should have used acetone on it first, and rub it or lightly scratch it. afterwards desolder usind the smallest adapter for the hot air, directing the flow only at the pins.
  7. The Following User Says Thank You to ominimicu For This Useful Post:
    martinracing (14th January, 2015)
    Feb 2011
    Almeria, Spain
    Quote Originally Posted by ominimicu View Post
    thanks for responding.
    Of acetone not what had done, that usually make either scratched before desolder to clean a little lacquer.
    But I will try to use first acetone.
    If air directly address it pins and when micros motorolla are what I do is the first direct hot air in the pins and also about the micro.
    thank you very much for helping
    temperature must be used with the station of hot air??
    Feb 2011
    Almeria, Spain
    Default where and how picture the circuit unit airbag whithout eeprom
    hello.
    Thank you all for help.
    But the damage to the circuit was done,
    to burn the tracks of the circuit
    I finally managed to remove the eeprom but the tracks are burned
    There may be possibility to connect an eeprom again
    but with detail on image to see the photo of the tracks of the circuit of airbag unit
    airbag control box is:
    airbag 550 80 44 00 8200018830
    You can help
    But in the image of the circuit you can see the tracks that is below the eeprom
    I hope help
    Thank you
    Where can I find?
  10. #9
    Youneselm's Avatar
    Nov 2010
    there are tracklabels to fix pbroken or damaged tracks.
    here is the link that you need made
    Kaisertech Ltd PCB Track Repair Kits
    did it serveral times works 100 percent good, no complains after 3jears yet
    press thanks if it was helpfull
  11. #10
    follow the tracks and join the eprom pins with cables to the next possible point. skip the tracks
  12. #11
    Feb 2011
    Almeria, Spain
    If.
    that do when leave the track.
    but as they have broken several tracks, no longer is that track corresponds to each leg of the eeprom.
    Therefore needed to see a clear picture with the eeprom removed the switchboard of airbag.
    circuit
    thank you
  13. #12
    Youneselm's Avatar
    Nov 2010
    thats also an option, but not so clean.
    with the pads its verry clean and profesionel job.
  14. #13
    Feb 2011
    Almeria, Spain
    Hello
    next time
    good clean legs, remove enamel, use acetone, and read the eeprom
    thank you
  15. #14
    Mar 2011
