possible to read with galletto 1260 via OBD & Xprog-M via BDM pads.
read ecu first with BDM or mpps
Thank you all
Galletto 1260's price is ok, and it can be done a lot of things with it, but I didn't found certain details that I can read this ecu...
What do you recommend ??
galletto or BDM
I had my DPF removed from ECU by www.evolutionchips.com which cost me ?285 with life-time warranty. The physical removal was done by a local garage with welding facility. Just cut the DPF body into two half, and then smash the ceramic DPF with hammer and chisel and then weld the exhaust pipe together.
you did well,better to pay for professional than open the ecu and ask for ''witch chip i need to read for dpf off''
ECU Tuning, DPF and FAP remove,EGR remove, Flap remove,DTC remove,Dyno tested files!!!
i have done dpf off on one of these, i have file here but i PAID for my file, i CHARGED for the job
spend money, make money
simples
"I always tell the truth. Even when I lie"
"We Taking Over, One City At A Time"
Hello friends,
Please help me to disable particulate filter on this car:
Ford Focus 1.6 TDCi 2006
I've manage to read the ECU with GALLETTO....
Please help !!!!!!
for free file use ecusafe,profesional job must pay, aaa suspect the injectors decode...if write to obd
problem is not in Galletto
ecusafe -1.6 ford ,mazda,Citroen etc... -big problem ,back fault dtc and regenration fap
these engines have a written code of injectors in memory ecu,if the write will be made by soft dpf off i OBD 90% injectors lost code ,later you will need to use the Ford IDS or codes to enter to ecu ....
I personally once again managed to do mpps by obd and it was not lost code injectors.. im wating 300 sec after reflash
summarizing:
1)ecusafe - will be big problems, from dpf regeneration mode will cause more oil in the engine and the car will smoke
2)galetto for Ford edc16...ehh
transmission if you do not fall..., then lose 90% of injectors codes
Ford tdci 1.6 does not ecusafe and manually and I use it to read and write BDM (safe)
yes you can write correct flash back
