Results 1 to 3 of 3
Hybrid View
    Member tirrofa's Avatar
    Default Coil driver location
    Hi All,
    Can anyone tell me of location or numbers for coil drivers on a Mag Marelli IAW 1AP.41 ECU. I have one loosing spark to cyl 2 & 3.
    Thanks in advance.
    Nige
    If I've helped please say Thanks
    locate the output pins of the coils on the ecu connector.
    using the multimeter to measure continuity, look for the IC or transistors which are connected to these pins.
    Romania
    Quote Originally Posted by tirrofa View Post
    Hi All,
    Thanks in advance.
    Nige
    use a vb025 ignition driver ic
