I have this problem and don't find answer....
my car have a US region MMI 3G system and I am trying to change the region and localisation of the MMI to EU because i want to have additional languages in the MMI.
I had done the following steps:
1. hiden(enginnering) menu activation
2. ....US>EU map flag changing
3. ....US>EU region flag changing
4. FW update by "emergency download" mode (8R090696T CD)
5. FW update by standard update mode.
Now my MMI have a HNav_EU_K0031_3_D1 FW release
but all texts in all menus is lost.
As i understand its happened because of configuration of MMI not correspond of the actual FW version. New languages are not initialised.
I doesn't see any new languages in the "engineering" menu and at the same time when i check standard menu for languages choise - i see only old languages which MMI have originaly (EN_US, FR_US, ES_US).
Anyone can share information - how to make actualization of MMI?
I need to update the list of languages...
find solution ?
I Am intresting too
simple OBD CAN comand, to activate new language set there is a tool on market for 250e, as i have seen or change langugae manualy using telnet or anything similar
I can help.
You need vag can pro, or open MMi and read, next change eeprom.
If you have VCP why do you want red and change eeprom. For what ?
There is a faster solution by VCP
Use VCP script or download eeprom data (via VCP or direct desolder) and change lang. list from NAR to EU
O man ...VCP do it automaticly. Why all want desolder or read and change eeprom. Why !?
