    Azzx's Avatar
    Sep 2011
    South Poland
    Default Audi A6 '98 - Tiptronic Problem
    Hey
    I have a problem with Tiptronic on 2.5 TDI Audi A6, 98 year.
    I have the DTC P0706 (according F125 switch) - on dash all gears ligten up.
    Changed switch - the same DTC.
    Disconnected switch - the same DTC.
    Checked the wiring (8 cables, 4 goes straight to TCM - all ok, 5- ground - ok, 6-reverse lights - ok, the two left goes somewhere else but they are okey near TCM).
    Any ideas (have anyone where the two left cables go?, blue with black strip, brown with white strip)?
    The TCM is under passenger carpet (don't have atm any other TCM for change).
    We choose to go to the moon.
    What would be life without a risk?
    vanos batam's Avatar
    Batam-Indonesia
    _______________ D3-oToprog _________________
    ig : vanos_batam
    Azzx's Avatar
    Sep 2011
    South Poland
    I have changed the F125 switch without success (I posted it above).
    Apr 2011
    in lebanon
    Quote Originally Posted by Azzx View Post
    Hey
    dear i thing b/w is for start system, and b/w is ignition, did you check is on the f125 have ignition after open ignition?
    Azzx's Avatar
    Sep 2011
    South Poland
    You posted twice b/w, you mean ignition by b/b - black blue?
    I figured that there is 12V on Black/Blue by some manual (haven't checked yet).
    On the Brown-White is also 12V?
    From manual:
    1+6 with ignition on - 12V, 1 is black-blue, 6 is brown - ground
    So what the brown-white stands for (number 7)?
    Thanks!
    Azzx's Avatar
    Sep 2011
    South Poland
    The brown-white goes to "V94 - Central Locking / Alarm System / Interior Light Delay Control Modul"
    The module is under driver carpet (LHD), so looks like there is problem with TCM - wiring OK, F125 OK.
