Results 1 to 8 of 8
    cartech's Avatar
    Default Mb A class remote not work
    hello!
    I have mercedes A class year 2006 (wdb169), key start, but radio/Ir remote not open/close the doors.
    I tested key all is ok
    I made diag with das no erros, then I made test value on sam (N10), have a little problem!
    I hahven't found second hand sam here in my city!
    is there any prcedure to repair thsi problem?
    thank u
    workshop
    Quote Originally Posted by cartech View Post
    hello!
    thank u
    first test battery on key(car started without battery)
    after radio frekfenze
    with das can you key frekfenz check
    cartech's Avatar
    hello!
    I already tested the battery of key....3volts
    I tested remotes with radio tester....ok
    I already programmed new key key (second key)...car start but remote not work too
    what must doing now??????????
    cartech's Avatar
    hell!
    this is my sam, how repair it?
    or possible to flash it again?
    give me hands please
    I haven't found it in my city, must found out of country!
    DK Veteran gtmech's Avatar
    Hell
    Whats the little problem you found?
    cartech's Avatar
    Quote Originally Posted by gtmech View Post
    not found any error dtc on this sam
    but when maked test of remote not recieved signal of the radio key in sam
    DK Veteran dontzapit's Avatar
    Feb 2012
    Iceland
    hello!
    what are using to program the remote keys? Did you buy the key from the dealer? These keys are hard to find
    DK Veteran lashkar97's Avatar
    Jan 2012
    Indonesia
    first u check remote that its show freq when u check it by remote tester . than other hand ur in Mercedes 3 type freq use 312 315 and 433 so ur car is which type freq support . and some time signal received antenna is not work . third may be some one make a key ur car and not sold mcu good. so check all option
