Page 1 of 4 1234 LastLast
Results 1 to 15 of 54
    Top Poster weedman's Avatar
    Dec 2011
    By my computer
    Default How can I use my Sky subscription in my DM 800 HD?
    I have a old style Panasonic Sky Digibox (No HD, or Modem input), with a subscription to sky until december.
    How can I use my sky card in my DM 800 HD?
    I read on this post, that the box posts back to sky through the modem, But seeing as I dont have a connection to the modem from my sky box, I dont have to worry about this right?
    http://www.digital-kaos.co.uk/forums...m800hd-100327/
    I would like to remove my Sky box completely and use the Sky card in my dreambox to decrypt the channels that I have paid for.
    So Its impossible for sky to know I'm doing this right?, seeing as I don't have a modem connection.
    Is this ok, will I get charged for 2 subs, or will the card break doing this in a clone DM 800 HD?
    - Thanks to those who deserve them, and none to those who don't...
    - DM 800 HD - Clone | DM 800 HD SE - Clone | Openbox S11
    - weedman
    digicon's Avatar
    No you can use it in the DM800 either by using an Oscam & CCcam config or if your not bothered about clearing PickTv channel then just use CCcam on its own. You just need your boxkey from your current sky box for this to work.
    Dec 2011
    By my computer
    Still no joy.
    I installed CCcam 2.2.1 on my 800 Clone.
    I edited the CCcam.cfg with this:
    BOXKEY: /dev/sci0 7digithex
    Inserted my card, activated CCcam, and restarted the box.
    But it doesnt work.
    What am I doing wrong?
    - weedman
    digicon's Avatar
    Quote Originally Posted by weedman View Post
    Still no joy.
    But it doesnt work.
    Its not 7 digits its 8
    Dec 2011
    By my computer
    oops..
    But how come when I convert my 10 digit serial number (after removing the first 2 zeros), (now its 8 digits), I get a 7 digit hexadecimal number?
    Example: (Not my real serial)
    My Serial: 0023780993
    Hexadecimal: 1C644BF
    Do I have to add a 0 to the front or something?
    - weedman
    Nov 2008
    i think the number off the sky box is more than 10 digits somewhere near 16 or 17 digits i think....sorry cant remember...and can't find my box
    smoggy's Avatar
    Apr 2009
    UK North East
    oops..
    Yes you put a zero in front
    Dec 2011
    By my computer
    Quote Originally Posted by smoggy View Post
    This didnt work either. What am I doing wrong?
    Here is step by step:
    1. Sky box Menu > 10 Digit Serial number
    2. Remove the first 2 `0's` from the SN.
    3. Use windows calculator to convert the (now) 8 digits, into a 7 Digit Hexadecimal.
    4. Put a `0` in front of the 7 digit hexadecimal to make it 8 digits.
    5. Install CCCam 2.2.1 full
    5. Put the line `BOXKEY: /dev/sci0 0H3XD3CI` (Not my real hexadecimal), Into CCCam.cfg.
    6. Insert my Sky Card, activate CCcam, & Full reboot the box (not just enigma)
    But still does not work. What am I missing in the above steps?
    - weedman
    smoggy's Avatar
    Apr 2009
    UK North East
    did you remove the # symbol at the beginning of the boxkey line
    Dec 2011
    By my computer
    Yes I did remove the line comment, There is no `#` Anywhere within the file, I deleted everything in CCcam.cfg and put in the line as above, without commenting out any lines.
    Still no luck..
    - weedman
    smoggy's Avatar
    Apr 2009
    UK North East
    I don't know much about the Dreambox but this is the instruction I followed when I had a card
    on sky box go to Services
    on the options select Settings
    Down button and select Details
    this will show your 10 digit serial number
    take the 10 numbers and convert them to hex
    (if it begins with any zero's these will obviously not go into calc)
    this will give an eight digit number
    (if less than eight then put zero's in front to make it eight)
    this number is your boxkey
    Use Dreambox Control Center to connect to dreambox and click on ftp
    then open the etc folder and right click on cccam config file
    then scroll down until you see the boxkey (line 317 I think)
    and delete the # symbol and replace the last 8 digits with
    your boxkey.
    Jan 2012
    I seem to have a similar problem with my DVB800HD
    I have a card with a full subscription (borrowed from a friend) and his 10 digit box serial number
    I've created the 8 digit hex key and altered the boxkey line in CCcam.cfg to read (including deleting the #)
    BOXKEY: /dev/sci0 ww xx yy zz
    I've also tried
    BOXKEY: /dev/sci0 wwxxyyzz
    Any suggestions?
  13. #13
    smoggy's Avatar
    Apr 2009
    UK North East
    Have you tried rebooting the box
  14. #14
    Nov 2008
    this is how my line is BOXKEY: /dev/sci0 22 2X 2X 22
    then you should activate the cccam and restart the box. that should clear the channels
  15. #15
    Jan 2012
    yep done all that.
    Is there any way of telling that the box is reading the card and that the card is valid?
