have u tried cleaning the vanes in the turbo??
"I always tell the truth. Even when I lie"
"We Taking Over, One City At A Time"
thanks for the reply yes vnt is working ok at about 100k this is a common fault certain conditions cause overboost and limp mode turn off and back on everything ok I think someone may be able to advise on either lowering boost or allow more boost before mil is activated
clean the variable giometry off the turbo.
bey bey error
how do I do that
remove turbo and clean it
or change the N75 valve + check the vacuum hoses,the hoses from the turbo to the intake manifolt...etc
ECU Tuning, DPF and FAP remove,EGR remove, Flap remove,DTC remove,Dyno tested files!!!
if the vacumm hoses, or N75, or intake manifold is defective or damaged, the car dont pull.
result no charge pressure in engine.
Overboost is only, generated by the geometry in turbo that blocks in the high pressure position.
TAKE OFF TURBO AND CLEAN THE VARIABLE GEOMETRY, AND JOB DONE.
thats what i said, CLEAN THE VANES
Listen to z786 hes right, its the veins sticking
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
OR A UNDER PERFORMING N75 VALVE.......the n75 are cheap enough,try and replace it,check all pipes
read the post please, turbo is clean, vacuum pipes are ok, it is not n75 it is the later square black boost unit on bulkhead it is ok. as I said these systems at about 100k must wear a little and cause overboost in certain conditions, I would like to know if it is possible to alter software to keep the light out
You can set boost limiter higher i mean SVBL
If it is just 'wear' all you have to do is adjust the actuator rod 10mm spannner open the lock nut and turn to make the rod longer .. done.
