Results 1 to 7 of 7
    DK Veteran sorgun's Avatar
    Dec 2011
    t?rkiye yozgat
    Default corsa c transmission fault
    corsa c 2001 year automatic transmission fault not diognos display F fla***351;ing what problem mta ecu fault help
    Sep 2009
    Read the fault codes.
    Aug 2009
    Bulgaria
    hi
    check motor brushes on cluch actuator
    regards
    Read engine ecu and g/box ecu,faults in either can cause your problem
    Jan 2011
    is that easytronic or automatic,,,there is a big differrent bitween those and when it showes F on display nothing is function on easytronic
    had this problem before, brushes in actuator, as you been already told m8. connected to gearbox m8, hope this helps
    dont forget to press thanks
    dimitar's Avatar
    wow stop the conclusions everybody. IF you want to solve the problem first post fault codes in ECU, TCM and BODY module
    50w Soldering Iron
    Chisel
    Sometimes Hammer
