Page 4 of 26 FirstFirst 12345678914 ... LastLast
Results 46 to 60 of 381
  1. #46
    Aug 2011
    USA
    Quote Originally Posted by dlogi View Post
    can someone tell me how these files are different than trim codes like 5232 or 6999?
    These are injector codes for 3406E and C-15 but not for the C15 acert. the 5232 is the best, the 6999 makes more smoke but no more power.
  2. #47
    Jul 2012
    thanks what I meant though is I see the posts of trim files. What is the difference between that and codes like 5232?
  3. #48
    Aug 2011
    USA
    The acert engines use a trim file and a conformation code.
    You cannot change fuel flow on a injector like a 3406E and C-15 with injector codes.
  4. #49
    Jul 2012
    Ok thanks for the explaination
  5. #50
    Top Poster innovateq's Avatar
    Palestine
    Quote Originally Posted by innovateq View Post
    Hi here!
    I need now this ones. Please help me!!
    2S0054118352
    2S0054119452
    2S0054119240
    2S0054118863
    2S005411904E
    2S0054119347
    Best regards!
    Hi here!, any help with this trims??
    Regards!
  6. The Following User Says Thank You to innovateq For This Useful Post:
    curreey (6th May, 2019)
  7. #51
    DK Veteran Gilang's Avatar
    Aug 2012
    Central Kalimantan-Indonesian
    Hi here!
    2S0054118352
    2S0054119452
    2S0054119240
    2S0054118863
    2S005411904E
    2S0054119347
    Best regards!
    Sorry to late, please take it
    If it my post it's helpful, please get push "THANK and REPUTATION"
  8. #52
    DK Veteran Poptest's Avatar
    Sep 2010
    Default Injector trim question
    Hello DK,
    I havent tried replacing CAT injectors. May I ask what the effects are on the engine if injectors are replaced without programming the trims on the ECM? Will it damage the engine, low power, smoke?
    Thanks...
  9. #53
    Aug 2012
    Talking
    Quote Originally Posted by Poptest View Post
    Hello DK,
    Thanks...
    Only do reduce power engine up to 2-6% when full load/ stall engine rpm, because influenced by each initial information from injector to electronic control module
  10. The Following User Says Thank You to Gilang For This Useful Post:
    mang5087 (29th January, 2014)
  11. #54
    Newbie carmenalonzo56's Avatar
    honduras
    PLease i need this trim files;
    2SL0148835BE
    2SL0148832AB
    2SL0148837BO
    2SL0148847DB
    2SL0148846DC
    2SL0148833AC
    Thanks in advance
    Carmen
  12. #55
    Jun 2011
    Is there an way to figure out the cal code other than having the injector in front of you?
  13. #56
    Aug 2012
    need injecter trim files
    5A510316339F
    5A51031629BC
    A550299262B3
    5A5103163096
    A55029079404
    A550304060C7
  14. #57
    Aug 2012
    Quote Originally Posted by ashkar View Post
    find the trim file in the list, look it up on sis or if you find the rar list here, open it with notepad and the ecode is near the injectoe number at the top of the file with<> around it
  15. #58
    Aug 2012
    Quote Originally Posted by cnckulp View Post
    you can change the flow on the accert injectors if you can find a high flowing one and then set them all the same
  16. #59
    Aug 2012
    these injector codes are in accerts as well but its encrypted
  17. #60
    Jan 2011
    I'm looking for this trim files. Can anyone help me please? 5a5041246498
