"Ok lets be real here for a min.. The injectors you had must have been on the lowest possible trim numbers or was it set to the lowest before the dyno so that when they were then changed to the highest it showed 150HP gain?
The total Gain attainable can be as much as 150HP depending on many factors and the most influential being the Nozzle orifice size."
"More EXTRUDE honing and what a destructive way to add fuel!!"
your personal prefrence thats probably because you were re-using the original nozzel... However they still meet cat engineer standard specs. Do you have those? I do.
"The % of gain in HP or actual fuel flow by way of altering the Trim will vary depending on the Nozzle Total Orifice size, Engine RPM, Actuator, and internal pressure rise proportional to Plunger velocity".
This ^ is wrong as well, Every caterpillar orfice on all 3406E models are .008. (Should never be changed).
If you change the orfice size: you lose weight and inertia. < This means its NFG! Ask a mechanical engineer or me =split tips.
I've seen your posts Far_Call/ Greg/ Western Diesel&Performance. On Truckers Page. You leave alot of misleading Information. for eg truckers page! "The Injector ECODE is not the trim" Well in fact it is. Eg. 3389<ecode>
0-9
1-8
2-7
3-6
4-5
5-4
6-3
7-2
8-1
9-0
ecode 3389 = 6610
Your obviously on the right page if you wanna get educated!
Caterpillar EUI***8217;s using ACERT injectors use 5 separate injection events all controlled electronically.
1. Pilot Injection
2. Main Injection Step One
3. Main Injection Step Two
4. Main Injection Step Three
5. Post Injection
Rate shaped unit injectors can be adapted to use three different injection rate profiles to achieve either good fuel economy (lean), good emissions (clean), or optimum power (mean).
Trim Codes
Since variations between flow rates of injectors can occur due to manufacturing tolerances, identical injectors can deliver different quantities of fuel despite the using the same length of PWM signal. This produces emission problems and cylinder imbalance conditions. To correct this condition, manufacturers will flow test all injectors and compare them against a nominal standard value. Depending on whether the injector flows more or less fuel, a numerical value is applied to the injector. This trim code or E trim value is entered into ECM injector data where adjustments to fuel flow can be made electronically.
