Results 1 to 4 of 4
    Lithuania
    Default Peugeot 307 BDM dump
    Please help with CS for this dump, it's Peugeot 1.6 hdi 2004, 9HZ engine, read dump with Xprog ( orig ) and make EGR and DPF off with ECUSAFE, now car not start, no errors, no authorization May be it's CS error? Read 2 times without errors, writing without errors.
    Please check check sum, thanks in advance,
    I can help with new autodata.
    DK Veteran ZIZZOU's Avatar
    Dec 2011
    yes,it's true,the cks is wrong in modifed dump
    Lithuania
    Quote Originally Posted by ZIZZOU View Post
    Big thanks, I will test it in monday,
    Regards,
    Wink
    Quote Originally Posted by Min2xx View Post
    nothing errors because ecusafe is stupid solution for dpf off,it mask all faults.you must to restore your org files ecu.Dpf off for edc16 must manualy remove from flash
