Page 1 of 3 123 LastLast
Results 1 to 15 of 33
    DK Veteran mathura's Avatar
    Aug 2011
    Default MACK ENGINE MANUALS
    Here is the overhaul manual for Mack E7 Engine-300 pages
    The ENGINE ASSEMBLY section includes stepby-step procedures for reassembling the engine. This helps to ensure proper installation and longer service life.
    The SETUP AND ADJUSTMENTS section has the latest setup information, complete with charts showing necessary data for adjusting all E7 engine models. Engines perform best and conserve fuel most efficiently when adjusted properly.
    Mack E7.rar
  2. The Following 11 Users Say Thank You to mathura For This Useful Post:
    AdrianCR (30th August, 2020), djz4248 (21st September, 2013), hieu1987 (2nd June, 2013), hum autobpic (8th June, 2020), igor75 (13th March, 2019), jm6734 (14th June, 2020), kvp61327 (13th December, 2013), mentos (19th September, 2013), muttsnuts2370 (22nd October, 2013), pbateman (5th September, 2013), peter21 (8th May, 2013)
  3. #2
    Nov 2011
    great job m8
    Aug 2011
    Default Mack E-Tech Manual
    Here is the Mack E-Tech (Electronic Version Of E7) Manual- 365 pages
    Changes from the Existing E-Tech Service Procedures Manual
    Mack Trucks, Inc. has made many major improvements to this E-Tech; Service Procedures Manual, with changes to both content and organization. This is a complete manual, describing engine features and the operation of major systems as well as providing comprehensive overhaul procedures, specifications and adjustments.
  5. The Following 5 Users Say Thank You to mathura For This Useful Post:
    djz4248 (21st September, 2013), hieu1987 (2nd June, 2013), jm6734 (14th June, 2020), mentos (19th September, 2013), peter21 (8th May, 2013)
  6. #4
    Aug 2011
    Default MACK Engine Tune-Up 2001
    INTRODUCTION
    Mack Trucks introduces the engine model line-up for 2001. Included in this line-up are the new E-Tech CCRS (Current-Controlled Rate Shaping) engines. The unit pumps used on CCRS engines utilize technology where electrical current supplied by the Engine Electronic Control Unit (EECU) controls the rate of fuel injection. This technology allows the shape of the fuel injection curve to be tailored, and also provides improvements to exhaust emissions, driveability and fuel economy. With horsepower ratings ranging from 275 to 460.
  7. The Following 5 Users Say Thank You to mathura For This Useful Post:
    djz4248 (21st September, 2013), hieu1987 (2nd June, 2013), igor75 (13th March, 2019), kvp61327 (13th December, 2013), mentos (19th September, 2013)
  8. #5
    Aug 2011
    Default MACK MP8 Engine Manual
    MACK MP8 -Euro 3 Engine Manual-342 pages
    The MACK MP8 (Euro 3) is a 13 liter (800 CID) engine with electronic unit injectors and an exhaust pressure governor (EPG) for engine braking.The optional PowerLeash engine compression brake is available in combination with the EPG for increased engine braking performance. The engine conforms to Euro 3 emission requirements.
  9. The Following 5 Users Say Thank You to mathura For This Useful Post:
    hieu1987 (2nd June, 2013), hrobertdm (21st May, 2013), igor75 (13th March, 2019), kvp61327 (13th December, 2013), mentos (19th September, 2013)
  10. #6
    Aug 2011
    Default MACK MP8 Euro 4 Manual
    The MACK MP8 is a 13 liter (800 CID) engine with electronic unit injectors, a cooled Exhaust Gas Recirculation (EGR) system and the Holset Variable Geometry Turbocharger (VGT). The PowerLeash engine brake is optional. The engine conforms to Euro 4 emissions
    requirements.
    The MP8 uses unit injectors. The unit injector incorporates the pump, valve and injector. Its internal solenoids permit fast, precise control of
    fuel delivery into the cylinder. The unit injectors are encased by the valve cover and not exposed to the heat of exhaust system components.
    Mack MP8-Euro 4.rar
  11. The Following 6 Users Say Thank You to mathura For This Useful Post:
    hieu1987 (2nd June, 2013), hrobertdm (21st May, 2013), igor75 (13th March, 2019), kvp61327 (13th December, 2013), MANYCERO (16th October, 2013), mentos (19th September, 2013)
  12. #7
    Aug 2011
    Default MACK MP8 Manual
    Mack MP7 Diesel Rngine Manual-364 pages
    The MACK MP7 is a 700 CID (11 liter) engine with unit injectors, a cooled Exhaust Gas Recirculation (EGR) system and the Holset Variable Geometry Turbocharger (VGT). With the addition of a Diesel Particulate Filter (DPF) system and changes in the EGR system, the
    design now conforms to year 2007 Environmental Protection Agency (EPA) requirements.
    The new MP7 EGR system features a venturi with Delta Pressure sensors. The MASS flow tube has been replaced. The new combination is easy to service.
  13. The Following 6 Users Say Thank You to mathura For This Useful Post:
    djz4248 (21st September, 2013), hieu1987 (2nd June, 2013), hrobertdm (21st May, 2013), igor75 (13th March, 2019), kvp61327 (13th December, 2013), VNL640 (30th May, 2013)
  14. #8
    Aug 2011
    Default MACK MP10 Manual
    Mack MP10 Service Manual -360 pages
    The MACK MP10 is a 16 liter (982 CID) engine with electronic unit injectors, a cooled Exhaust Gas Recirculation (EGR) system, a Diesel Particulate Filter (DPF) system, a Holset Variable Geometry Turbocharger (VGT) and the PowerLeash engine brake as standard equipment. The engine conforms to year 2007 Environmental Protection Agency (EPA) requirements.
    Mack MP10.rar
  15. The Following 5 Users Say Thank You to mathura For This Useful Post:
    djz4248 (21st September, 2013), hrobertdm (21st May, 2013), igor75 (13th March, 2019), kvp61327 (13th December, 2013), outinout123 (1st September, 2016)
  16. #9
    DK Veteran RSwire's Avatar
    your girlfriends house
    Thanks again for these manuals, I was wondering if you or anybody have the manuals for the older macks, R, DM, RD model Macks with the 237 or 300 engines with the duplex/quadraplex trans and topload rears. We got alot of these around our area because people are afriad of change . I could really use these manuals. Thanks
    A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
    Please don't pm me for keys, that is what the forum is for.
    If it helped, please use the thanks button, if thanks isn't enough use the scales.
  17. #10
    Aug 2011
    Quote Originally Posted by RSwire View Post
    I think that the RD models uses the E7 engines which varies in hp but if you need other information on transmissions, brakes, axles etc I can post because I have some info.
  18. #11
    Aug 2011
    Default MACK Marine M-E7 Manual
    This manual and illustrations relate specifically to the heat exchanger cooled version of the marine engine.
    The engine reassembly procedure includes step by-step instructions for reassembling the engine. This helps to ensure proper installation and longer service life- 331 pages
    Mack Marine M-E7.rar
  19. The Following 3 Users Say Thank You to mathura For This Useful Post:
    igor75 (13th March, 2019), outinout123 (1st September, 2016), tap50 (10th June, 2013)
  20. #12
    Aug 2011
    More manuals to come friends on MACK
  21. #13
    Aug 2011
    Default MACK E6 Manual
    MACK E6/672 C.I.D -2Valve.
    Mack E6-2 Valve.rar
  22. The Following 5 Users Say Thank You to mathura For This Useful Post:
    djz4248 (21st September, 2013), hieu1987 (2nd June, 2013), igor75 (13th March, 2019), muttsnuts2370 (22nd October, 2013), peter21 (8th May, 2013)
  23. #14
    Aug 2011
    Default MACK Cooling System- MP7,MP8,MP10
    MACK Cooling System Manual
    All current-production MACK engine cooling systems for diesel-powered chassis are the sealed, pressurized type. Sealed, pressurized systems provide for a higher boiling point of the coolant mixture. Each psi of pressure in the system raises the boiling point of a 50/50 coolant mixture (ethylene glycol and water) 1.47?C (2.65?F). A 50/50 mixture of ethylene glycol and water has a boiling point of 108?C (226?F) at
    atmospheric pressure.
    This manual is intended to provide the technician with an understanding of how MACK engine cooling systems operate in diesel-powered chassis. This manual also assists the technicia in proper diagnosis, maintenance and repair of the cooling system. The information in this manual is divided into eight major sections covering Introduction, Description and Operation,Troubleshooting, Maintenance, Repair Instructions, Specifications, Schematic and Routing Diagrams,and Special Tools and
    Equipment.
    Cooling Sys MP7-8-10.rar
  24. The Following 3 Users Say Thank You to mathura For This Useful Post:
  25. #15
    Quote Originally Posted by mathura View Post
    Thanks, any info would be great, the trucks around me are form 1975-1990 for the most part. Before ecms,dpfs, all electronics I used to use the old Mack Master Manuals, alot of books with every thing you needed to know about MACK. Keep up the excllent work you doing for all of us here.
