laserkill (9th June, 2016)
what should i do now i hav find a burned fuse 38 central locking. but in 2 right back door all wire are cut and now 12v in there what should i do.thanks
I've heard reports of disconecting the battery fixing locking faults like this.but.tomorrow.i.will.try
just dont forget to take the key out of the ignition before disconnecting and reconnecting the battery
sloved thankyou very very much
How did you solve? I have astra G all 4 doors deadlocked only boot opening can hear the central locking disengaging but doors wont unlock.stays deadlocked. Any help will be greatly appreciated.
Yes friend check the wire in back door you will find a cut wire connect the wire with soldering when you finish it check the fuse if is every thing with fuse than disconnect the battery for 1 min than hold locked or unlocked button for 30sec or 1 min. For me olways work. Good luck
geeroam (15th February, 2015)
Hello,i have same problem but when i disconnect battery remote works ok but after insert in ignition and start car then stops again,any ideas?
Thanks in advance
many times i encounter this problem
the problem is micro switch inside the lock stay in on position even the key is out
remote will work only if key is not inserted in the ignition lock
