Results 1 to 1 of 1
    Default Santa Fe New Model Fix outside temp sensor fault
    Problem with 2006 Santa Fe. Outside temp sensor showing 20C all the time on display. Affects auto heating Aircon. Apparently this is a problem with a lot of these. Easy fix to bypass connectors in engine bay fusebox. Details Hyundai TSB attached.
  2. The Following User Says Thank You to BRAVO6 For This Useful Post:
    gomarota (25th August, 2016)
