Results 1 to 11 of 11
    Jan 2012
    Default Openbox S1 complete noob, any help appreciated.
    Hi guys. I'v Just got my S11, and i had a quick fiddle around with it, but still waiting for a new ethernet cable so i can hook it up to the net.
    While i was waiting i thought id ask the shameful noob questions
    Firstly and most embarrassingly.... i just need to plus in the two satellite wires, Ethernet cable and HDMI to tv right?
    Secondly, i'm using my existing sky sat dish, i was wondering if i can connect sky and openbox at the same time to the dish? will it work?
    Thirdly, is there anything else i need to do to get it working?
    Im sorry if this post feels like a waste of time but im really looking forward to using openbox and really would appreciate any help.
    Thank you in advance.
    Top Poster kianniamh's Avatar
    Plug it in and connect as you mentioned, that will get you the freeview channels. To get the rest will take a little searching try cccam.
    You will need a dual lnb or more to connect your sky box too.
    Hope this helps a bit.
    DK Veteran darcu5's Avatar
    Jun 2011
    Bolton, Lancs.
    Just one wire from the dish.. if you check back of box it says- in - and loop out, the loop out will connect to another box but you cant watch both at same time.. (well i couldnt when i tried the s9 looped into a sky box)
    Anyway,, just plug one wire into the sat feed in
    If it isn't broke, don't try fixin it..!!!
    Jul 2011
    Quote Originally Posted by mosthafa View Post
    Just to watch Freesat style programmes a network connection is not required
    You can't share a downlead between two satellite receivers. If you have a dual or quad LNB then you can use a separate cable to each of the Sky and Open boxen at the same time, but you can't splice a single cable and conenct it to both receivers. Reason: the receivers send command signals back up the wire to the LNB. 2 sets of signals will confuse it.
    Batteries in the remote control?
    Jan 2012
    Thanx for the help, im going to get a dual lnb soon, for the time being i nicked the sat for the openbox... all the freeview channels seem to be working what do i do about the channels that say scrambled?
    yeh i stole batteries out of my tv remote for this as well .
    Feb 2011
    darwen
    google ccCam
    Dec 2011
    Default help
    favourites section openbox where can i get channels from
    Jan 2012
    googled ccCam, followed every instruction i could find... but the channels are still scrambled
    Daft question:- have you paid your server for the Cccam?
    Have you tested with a test cline? you can request one which are usually free for 24 hours?
    gmb45's Avatar
    Nov 2008
    park bench, hedge bottom, police cell
    carefull now !!!
    Thought I might be sailing close to the wind with that one.
    Didn't think it was too detailed.
    Apologies.
