Programmer like Elnec Beeprog, Galep, Batronix BX48 ...
only desolder and read?nothing by obd plug like galletto 1260 or spi28?
There is a word on the street original galletto can do it ... but clone surely can't.
Galletto clone with L-Line works with them
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
in my case it doesn't. I have a galletto 1260 clone connected like that, I also connected it in the car obd plug, but didn't connect. Could it be that, because I have an immo problem and the engine won't start, blocks the connection between the ecu and galletto? I am thinking, could it work if I connect an emulator at pin 58?
Can read with clone galletto but must make ground to boot pin .
Thanks kev
One little help.
one question:we lift the pin up and the solder, or it doesn't make a difference?
No need to lift pin.
well, nothing happened so far.i think that this is not the boot pin for my ecu because i have sirius 32,not sirius32n.i found something searching in google. does it works with galletto clone?
Hi guys I tried this possibility bootmenu no goes.
There is also solution with the simplest KKL interface and software ddt2000 for this type ecus(for reading full flash-29f200bb).
and where can we find this kkl interface and ddt2000 software?
