instal v12 software
right click icon in device manager
click install driver and look in mpps program folder
instal v12 software
"I always tell the truth. Even when I lie"
"We Taking Over, One City At A Time"
Yes, that helped, but now the message no external voltage appeared. Anything? :|
dont you get that error when the obd is not connected to the car......have you tried it on the car
plug into car mate
D Don't be funny. It might be bad MPC solder?
.im sure if you have the mcu on and the drivers updated then your there...
??? MCU soldered OK. Checked all pins. Connected to the car --> no external voltage... Any1 had such issue?
download and take a look at my 2 photos of mpps pcb....
on picture "mpps 1" you see where voltage comes in to pcb and goes to the diode es1b then on picutre "mpps 2" you can see where the voltage goes out over one smd resistor 4702 and then goes to the mcu pin that is marked on picture "mpps 2"
check out with multimeter if you get voltage till the resistor 4702 and then check the solder of the mcu pin that reads the voltage.
check also this both resistors where the voltage goes trough on picture "mpps 2" if these are not good soldered you will get that error with voltage too.
regards
where can i buy a v12 mcu
CAN YOU HELP ME I NEED THE DRIVER V12 FOR MPPS
hope this helps...
MAGPRO X17--AT-200--SCANMATIC BENCH--PCMFLASH--MITSUBISHI MUT-III---OPENPORT 2 MMC FLASHER
: ***1575;***1604;***1575;***1587;***1578;***1605;** *1575;***1593;:: giveup:
