Page 15 of 29 FirstFirst ... 5101112131415161718192025 ... LastLast
Results 211 to 225 of 423
  1. #211
    Nov 2011
    Kitty-Hawk, thanks for posting this.
    Can you please pm me the password.
    Thanks in Advance !!
  2. #212
    Member andreytora's Avatar
    Good day!
    Please, can I have password?
    Who not with us - that against us, and no hatred - a work only!
  3. #213
    Jul 2012
    Bel air MD
    this works on v mac right?
  4. #214
    Password please many thanks
  5. #215
    Feb 2012
    Hi all. I managed to make the cable for nexiq to renault obd2. It works perfectly, can read and erase fault codes, everything works fine until vcads asks to switch off the ignition wait 10 seconds and turn on the ignition!
    When i turn the ignition on it does not recognise that the ignition is on. Can anyone assist me with this please?
    Maybe there is an additional wire i must connect????
    Thanks in advance!
  6. #216
    Feb 2012
    VOLVO FM12 380 - GEARTRONIC (AUTOMATIC) - TRUCK IS OPERATING EXCEPT FOR THE GEARBOX. IT TAKES GEARS SMOOTHLY WHEN TAKING OFF AND GOING FORWARD BUT THE PROBLEM IS THAT WHEN YOU COME TO A STOP, IT DOES NOT WANT TO TAKE GEARS - IT JUST STAYS IN NEUTRAL. SOMETIMES IF YOU PULL OUT THE K5 RELAY AND PUSH IT BACK IN OR TURN OFF THE IGNITION IT STARTS TO TAKE GEARS AGAIN BUT I HAVE TO DO THIS EVERY TIME THE TRUCK STOPS AGAIN.
    THERE ARE NO FAULT CODES ON THE GEARBOX ECU AND THE GEAR SELECTOR ECU.
  7. #217
    Sep 2010
    disable the tranny auto neutral if possible, i am not sure you can do it with Vcads, this is a known issue with volvo passenger vehicles and the solution is to reflash the tranny module with one which has this feature disabled.
  8. #218
    CARIBEAN
    Default volvo installation problem
    i have tried to install this several times in different machines but it gives me the same problem in all machines
    problem to install the sql
    i have tried everything from installating the sql to erasing and re installing the software even erase the installation and begin a new one but have the same issue if some one could help me with this i really would apreciated
    thanks in advance to all in the forum
  9. #219
    Sep 2012
    I have the software installed already and a keygen file but the keygen will not open. Does anyone know if i just need the password or what
  10. #220
    Hello Kitty hawk. Could i please have a password? Thanks.
  11. #221
    Feb 2011
    Please password
  12. #222
    Feb 2012
    Default Sorted
    Quote Originally Posted by parezoo View Post
    Turns out it was the speed sensor causing the problem! No fault codes yet replaced the sensor truck perfect!
    Thanks again Parezoo!
  13. #223
    Oct 2012
    I am looking for a user name and password for my tech tool any help
  14. #224
    Thank you
    May I have the password?
  15. #225
    Thanks, Man
    Password please,,,,
