I cant find the parameter to change the automatic transmission into a manual I readed that its in vehicle adjust id FTY somebody can give a screenshot please??
Greetings friend, could you provide me the PASS, thank you very much in advance
can someone help me please .
okay I'm trying to install this program which is the right ID number for this program are which ID number words with this 1.11kg I will appreciate any help or any idea thank you
I have a 99 volvo with vers 2 elect.No matter what parameter I change,I cant get rpms over 1600.The speed sensor harness is trashed and Im geting speed sensor codes active.If the ecm doesnt register speed is it like a cummins and cut rpms until speed is reg?Thanks for any help with this problem!
Yes it is a ver2.This is an offroad application.Is there a parameter I can change to stop this derate.I have developer tool but I cant find the one I need.Thanks!
PLEASE PASSWORD
Is there any one who works for Mack or Volvo dealer?
I need to ask something. Plase contact on pm.
PLEASE PASSWORD
PM password please !
THANKS
Repair the harness and replace the speed sensor if necessary! This will solve the issue of not getting past 1600RPM! After you have repaired harness check fault codes! if you get a code in the engine ecu MID128 PID84 FMI9 and one in the vehicle ecu MID144 PID84 FMI2 replace the speed sensor! Just remember when replacing the speed sensor you must pair the sensor to the tacho or the cruise control and high idle will not work!
In parameter programming you can only increase the engine speeds, however this will only work if the speed sensor and tacho are communicating correctly
Hope this helps
Thanks for this - it's appreciated.![]()
Password Please PM
