anyone know where i can get these broken component?
i have a problem...
i have tried to read out a passat 1.8T with mpps v5.
as in describtion 12v+ on pin13:
i have solder on my mpps inside a cable on pin13 the other end i have put on a the car battery 12+ , now the mpps is dead i will upload a picture....
have the mpps inside already 12+ on pin 13????
regards
are you 100% sure that you connected it to pin13? you should just bridge pins 16 and 13.
anyway consider yourself lucky to brick only that shitty chinese clone, not the ECU.
you probably reversed something, are you sure you are looking from the right side, maybe you mirrored the whole thing?
what year is your passat?
no it was pin 13, because it was written pin16 on the mpps, i have check it two times with a multimeter.
year 1999
4B0906018AL shows vagcom
ok other fault is....
the ecu is me7.X
that is ME7.5 with 29F400 inside any should be OBD flashable, maybe on those early ME7.5 there is no wire between ECU pin 43 and OBD pin 13
yep in case od ME7.5 no need to put 12V there, but that doesnt explain why you killed your MPPS
probably it is meant 12v+ through pin 13 obd or direct to ecu pin43, but not on mpps...
