Results 1 to 15 of 30
    May 2011
    Illinos
    Default ACTIA Multi-diag serial number setting
    During installation, when Multi-Di@g configuration window appears, we should set Communication interface to USB and set VCI serial number to A070026:
    After installation, MultiDiag shows message asking to get activation code. Click the tick button. Enter the password and click the tick: (passwork come from supplier, tell them the code 18-...)
    During diagnosing with the device connected, a warning about 0 days left will appear. Just check the mark ?Do not display this message again? and continue the work, everything will be working ok:
    Video on How to use Multi-Diag:
    how to setup multi-di@g access j2534 pass thru.avi - YouTube
    Greetings
    TOINO's Avatar
    Jan 2012
    good day friend, install new soft ACTIA ee puts the number of vci that your provider gave you the same number of vci who already have at the end will ask you the key. i ask me I give you the chace already and it will work again
    Jan 2011
    help please 19-8F2C2EA0ZAY
    Thnx
    Senior Member lihaven77's Avatar
    Jun 2009
    Quote Originally Posted by ciftci63 View Post
    Thnx
    D573963C139DFCB6
    Jan 2011
    Pls code for multi diag ver. 10.1 (19.10.0519)
    ID - 19-31EAC471SUU
    THANKS
    miha99's Avatar
    EU
    ID - 19-31EAC471SUU
    63932CFAD79874D4
    Nov 2010
    Hello
    I've got a problem with the Multi Diag i bought 6 month ago. There is a message : "your subscription ends in 8 days".
    What do I have to do ?
    Nov 2010
    My version is : Multi-diag office DVD II-2011 (23.07) Automotive VCIA093479 .
    Thank you very much !
    Nov 2010
    Ident:21-23A58132VCD
    Interface:093479
    Code activation:20F2886FD5BE12D8
    Sep 2012
    Default hello admin
    can i help frends and upload actia key generator KG_MD_I-2010
    Member jpay2's Avatar
    Toulouse
    Hi, can you give me an activation version 2010.I
    Hardware: SN/069439
    SOFT: 19-7BCC0411S2B
    Thank you.
    miha99's Avatar
    EU
    Hardware: SN/069439
    pass:
    431730D0A5408512
  13. #13
    Mar 2011
    Hi guys I need HELP I have Multi Diag (Clon)
    Hardware Serial number 070026
    I have Install Multi Diag III 24.10
    When Install I will put S/N 070026 in new window come Incorect Srerial number,.... I have test on two laptops with same S/N number....
    Have you any idea for this Solution with clone Interface ??
    Thanksss
  14. #14
    TOINO's Avatar
    Jan 2012
    jpay2 your key
    431730D0A5408512
  15. #15
    Dec 2010
    hi
    i have multidiag china interface i whould like to install multidiag 2011 software.
    if possible please give me the procedure .
