Results 1 to 2 of 2
    DK Veteran trigital's Avatar
    Default BMW E60 read it with AVDI
    I read this file with AVDI from 3.0Diesel E60. This ws tuned and car is OK, but has a problem with exhaust temperature senzor. The tuner explain about changing the temperature map for keeping low temp.
    I think this is not a good ideea, because the dpf regeneration can not achieve desired temp.
    It has fault codes regarding 'dpf regeneration to often'.
    Can some expert look at this file and advice?
    Regards,
    Default attach
    Why I can not attach this file?
