Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Dec 2011
    Default Just got me an S11
    Well, I have taken the plunge and got myself a box off Ebay for ?66.99 delivered Special Delivery.
    Hooked it all up and all seems well
    I could do with some suggestions on how to get the best out of it
    Maybe you could private message me on what's out there ?
    Dave
    justanil
    Guest
    Default I think i got the exact same box!
    I also just got my box off ebay today, same price prob same seller. I set it up and seems to work fine!
    What help you need?
    Im trying to sort out the channel lists and favorites for easy access to my channels. I have Sly UK + Asian Channels (5ee, 5tar plus etc..).
    Anyone got a 100% UK channel list for these?.. Im searching till I find a good one that works for me (trying to make my own, using others and editing them).
    Also, I get most the freeview channels in the UK, except a few (5, 5+1, US, US+1), is this a problem with the box or the dish?.. kinda stuck on this one issue.
    Finally, can i customize this box in any way?, style and epg and stuff? (Links to guides/tutorials would be appreciated)
    Anyways, I got a satellite guy coming wednesday to extend my current dish with 1 output, to hopefully 3 more rooms!!
    Any help from an openbox master would be appreciated!
    Maybe i'll write up a openbox start to finish tutorial for noobs like me once I get the hang of it.
    justanil
    Guest
    Update: For my S11 Box, (Cloned)
    This channel list does not work: (Sticky)
    http://www.digital-kaos.co.uk/forums...oxe-s9-194832/
    I dumped all my channels and hopefully I can make my own to work.
    DK Veteran darcu5's Avatar
    Jun 2011
    Bolton, Lancs.
    Your better off making your own channel list on the s11 box itself. scan 28.2 then go into menu - edit channel - tv channel list select favs, scroll thru channels and select a channel you want, then the option to drop it into favs will pop up, and select where you want it,
    once you have channels in favs, you can then select to move the channels into some sort of order..
    As for 5* and 5usa, they have just changed transponders so you will have to manually insert the transponder and scan it.....
    If it isn't broke, don't try fixin it..!!!
    DW190
    Guest
    You could try this one.
    Nov 2011
    Quote Originally Posted by expostie View Post
    Dave
    are these clones, you checked?
    Dec 2011
    No, not checked if it's a clone.
    Working fine for me.
    Is there an issue with clones ?
    Shite Link King Shady's Avatar
    Dec 2010
    192.168.1.xxx
    there can be, some firmware includes a clone bomb
    - goto menu
    - tools
    - information
    - now enter 7 7 7 7 7 7 on the remote.
    If the CCID is one of the following:
    1) 00d0
    2) 00ea
    3) 085b
    4) 0d0c
    5) 98a1
    6) 98f2
    7) 9cf4
    8) 9d1a
    then its a genuine box
    Top Poster weedman's Avatar
    Dec 2011
    By my computer
    Default yey! I got a genuine one. :D
    Quote Originally Posted by shadyback View Post
    - goto menu
    - tools
    - information
    1) 00d0
    2) 00ea
    3) 085b
    4) 0d0c
    5) 98a1
    6) 98f2
    7) 9cf4
    8) 9d1a
    7 7 7 7 7 7 (six times) did not work for me.
    BUT..
    8 8 8 8 - did, it shows CA CARD & CHIP ID (which is 085B for me)
    I have a openbox S11 (genuine).
    In case anyone is interested, I bought it from this guy.
    Very fast delivery (next day), well packaged, original box and so far works great!
    Here is the seller I purchased this from:
    OPENBOX S11 HD PVR **LATEST FIRMWARE FEATURE** +3 PIN UK PLUG & HDMI | eBay
    Nov 2011
    Quote Originally Posted by weedman View Post
    BUT..
    same as mine, working perfectly
  11. #11
    Oct 2011
    BUT..
    damn that link is dead oh well hunting i will still go dont by any chance see if you have ebay userid? thx in advance
  12. #12
    DK Veteran nibblitz's Avatar
    May 2010
  13. #13
    Dec 2011
    This is the same guy I got mine off.
    Local to Stockport - ?60 if you pick up yourself !
    Had no issues with it at all. My son loves it. Watching the darts on sly.
  14. #14
    Jan 2012
    Hi guys looks like I got mine from the same seller mine it also same chip Id and working great,only thing I hate the the 3 columbs in the channels menu when you press OK you cant see the full channel name particularly bad for S/sports 1 2 3 etc. Any way to get a single columb???? anyone? Otherwise real pleased with it for ?66.99 delivered rapid like.
    Thanx G........
  15. #15
    Dec 2008
    My Chip ID shows 10AA
    Is this a problem?
    what the difference between clone and original boxes?
    am I going to get problems?
