Results 1 to 15 of 15
    Default Opel corsa C don't start
    hello,
    Opel corsa-c
    year: 2005
    1.3 cdti
    the car don't start, with diagnosis it show only one error:
    P1700 ( after i have deleted this error it does not reappear ).
    Sometimes the diagnosis instrument don't work on the car.
    Have you any suggestions?
    thank you!
    P1700 tells you the gearbox has (or had) an error.
    Also read the codes from the automatic gearbox to find out what the problem is there.
    If the diagnostic equipment doesn't work, do you have an engine light on then? And power to pin 16 of the diagnostic connector?
    What do you mean by don't start? The starter motor doesn't turn? Or the engine doesn't fire up.
    Quote Originally Posted by oldford View Post
    i turn on instrument cluster, i turn the key and the car don't start:
    the starter motor doesn't start.
    There aren't error, with texa diagnosis sometimes diagnosis work, the op-com not work.
    When i turn instrument cluster on i listen the rumor of injection but when i turn key nothing happens and there is no sound : starter, motor etc....
    Senior Member djamelEZS's Avatar
    IMMOBILZER IN CORSA C STORED IN DASH ECU BCM IMOBILSERII AND KEY
    MAY BE YOUR PROBLEM IN ENGINE CONTROL MODULE FIRST TRY TO VERUFY CABLES IF NOT CHANGED IT
    Ashraf6119's Avatar
    UK
    Sounds like Immobiliser fault...................
    It looks like you have poor connections in your Instrument.....So can you remove the Instrument and check the multi plug of instrument............
    Can you also confirm if this vehicle has Automatic Transmission or, its Manual Transmission.........Also have you tried to power up the starter motor directly and see if the starter motor is OK
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    Quote Originally Posted by Ashraf6119 View Post
    the car have automatic trasmission
    Ashraf6119's Avatar
    UK
    Quote Originally Posted by tunnel View Post
    Do you have (F) fault sign on your instrument..........
    Thanks Ash
    N and after i press brake it show F
    Ashraf6119's Avatar
    UK
    OK you might have poor earth connection at the Engine ECU or, one of the Gear Shifting Motor have failed or, fault in the clutch system............Can you try tapping the motors on the gearbox and see if that that's helps...........
    Thanks Ash
    DK Veteran Larue's Avatar
    Somerset, UK
    Hang on a minute!
    Have anybody checked Engine Control unit communications wiring diagram?
    I don't have it with me at the moment but if i remember right then communication with engine control unit is going thru Easytronic(gearbox control unit).
    So....if there is no communication with engine control unit but scantool communicating with all other control modules then that bit in easytronic is missing(even if there is comms with TCM).
    I agree about earth/power supplies checking and check what's going on on CAN lines with oscilloscope.
    Any faults in other control modules?
    Meat-Head's Avatar
    Quote Originally Posted by Larue View Post
    Hang on a minute!
    1) Nice phrase
    2) not going to argue, but agree and disagree with you
    *THINK* if you unplug the autobox, then intergiate the engine ecu
    it says "some bastard has stlen the autobox"
    Like wise beleive the gearbox ecu says "Some bastard has stolen the temp signal"
    3) Wounder if it's parked next to a french car - two faults
    Meat
    Top Poster Dr.Bojan's Avatar
    Serbia
    That car with Easytronic gearbox have many problems.
    First problem is 2 small motors and you can change that parts and secound problem is ECU, becouse drivers for clutch burn. On your instrument cluster when you put ignition ON, N will flash. If you press break then you will get -F- fault. You must check with your diagnistic over Test ACtuator, Is problem with ECU or motors.
  13. #13
    Ashraf6119's Avatar
    UK
    Any Up Dates On This One.....................
    Thanks Ash
  14. #14
    Feb 2012
    if you hawe easy tronic the problem is motors on your gearbox
  15. #15
    hi friends, i am unmounting MTA to change parts.
    I let you news soon as possible.
    thank you
