Results 1 to 15 of 24
    May 2011
    Russia
    Default Mini Cooper 2003 searching full flash HW08 Sw18
    After trying to correct mileage i have "black box".
    I used ROSFAR and it can not connect this dash,
    i had success reading only with ETL onboard but flash was already corrupted.
    Can anybody help?
    Mini cooper 2003 KM
    BMW part 6211-6928884
    HW-08
    SW-18
    DK Veteran technobox's Avatar
    cyprus
    pls send pictures and km or mil i check for u
    never lost anythink only change ...
    Nov 2011
    which is the exact model for this cooper ?
    what is the exact VIN number ? (last 7 digits)
    May 2011
    Russia
    CARPARTS VIN in PM
    Nov 2011
    here is flash, HW 09 SW 19
    if this dash is not the "chrono-pack", then you can use it
    if your car has this feature chrono-pacjk, let me know, i will send other flash.
    this data you can put back in the micro by using the option "recovery flash" in the rosfar tool
  6. The Following User Says Thank You to CARPARTS For This Useful Post:
    transprotector (18th September, 2014)
    May 2011
    Russia
    Sorry, what does it mean "chrono pack"?
    Nov 2011
    chrono pack is that model with a dash what have 3 needles, instead of the regular dash
    will upload some pic
    moment
    Nov 2011
    this is "chrono pack"
    this is an option
    the name "chrono pack" speaks for itselfs
  10. #9
    Nov 2011
    sorry, i said 3 , have 4 needles
  11. #10
    May 2011
    Russia
    No, no chrono pack.
  12. #11
    Nov 2011
    oke, then my uploaded flash is oke for you.
    chrono pack-flash is little different...
  13. #12
    Nov 2011
    but you write rosfar was not able to connect, only etl
    my file is a "rosfar" file from 128 kB
    the "real" flash has 2048 Kb
    possible to connect ? or you need "normal" flash ?
  14. #13
    May 2011
    Russia
    Yes, i can t read tis dash with Rosfar. All connections are as in manual, but no result. Yesterday i tried to make flash file for X-prog and write it, but without success. Can you give me "normal" flash?
  15. #14
    Jun 2011
    bosnia and herzegovina
    here you ware good 912secured flash.
    pass pm
  16. #15
    May 2011
    Russia
    Friki, is this file yours? What HW and SW?
