Page 1 of 3 123 LastLast
Results 1 to 15 of 44
    darwins's Avatar
    UK
    Default BMW ISN Read / Edit Software ?
    Hello Friends.
    Can anyone help me with software to read ISN code in MS41.0 with TMS chip (address location) etc ?
    A cloan copy or a link to original, preferable software which works with BIN files..
    I will never share pass's please PM me if you prefer..
    Darwins
    Go for it. The future is promised to no one
    darwins's Avatar
    UK
    I understand their is no immo off for this ECU type with TMS chip. If there is a solution please help
    If not can some one help with the ISN...
    This is for a kit car hence no immo wanted
    Darwins
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    Nice attachment. A empty folder?
    darwins's Avatar
    UK
    Ooops I will correct this in ten
    There is now furniture in the folder.......
    darwins's Avatar
    UK
    I'm still digging on this one.
    Does anyone know where the ISN code is in the above BIN files ?
    Is it in the MS41.0 ?
    I don't have IMPA (it looks like it takes it from the ews?) I do have Autologic, ecu info shots below. I don't see ISN, do you?
    I have tried reading directly with attached software but this has the TMS chip which is not covered...
    There is no EWS available for this car it was crushed when the doner car was sent for scrap
    It's now going into a kit car, the car is not local to me so im disadvantaged on option.
    Help would be very appreciated, I will not share help so please come forward if you can help...
    Darwins
  6. The Following 4 Users Say Thank You to darwins For This Useful Post:
    ecufix (2nd February, 2025), electronicdeivi (17th June, 2024), radstorm (17th October, 2016), traxpalicaru (20th May, 2020)
    darwins's Avatar
    UK
    Does anyone have original EWS editor ?
    Will this do it, Im happy to pay !
    Maybe the ISN is not in this ECU?
    I think its best to buy MS41 with 28f200 inside and make immo off for it. I have done a few and works perfectly. Or use INPA to read ISN.
    darwins's Avatar
    UK
    Hello F4kk3r
    Does INPA read ISN direct from the DME ?
    It looks like it reads data from the ews.
    Maybe a replacement with MS41 with 28f200 inside could be the answer.
    I have found this post: http://www.digital-kaos.co.uk/forums...f-2-8l-246349/
    Unless ISN can be read from what I have I will try this, it's not the same exact match by part number so I have no idea how it could work out, I'm trying to get this right first time
    My head hurts
  10. #9
    Dec 2010
    I haven't seen the ISN in the flash chip, and after reprogramming the ECU to a different version, I see the ISN remains the same.
    You can not reflash this ECU to immo off, so a later version might be better.
    You can also get another EWS box with key chip from another car, and then sync the EWS.
  11. #10
    Default SOLUTION
    whit EWS EDITOR read ISN from EWS dump and whit EWStoemu write ISN to DME
    THEN SYNC whit INPA
    TESTED
  12. The Following 3 Users Say Thank You to cricstudio For This Useful Post:
    javyb (14th December, 2018), rumensivanov (20th May, 2021), traxpalicaru (20th May, 2020)
  13. #11
    bram380's Avatar
    Indonesia +628153111774
    Put used ews2 & resync dme-ews
  14. #12
    DK Veteran gtmech's Avatar
    Hell
    Quote Originally Posted by bram380 View Post
    ????? You been drinking bram380? Its not that simple, it wont work as easy as that mate
  15. #13
    vanos batam's Avatar
    Batam-Indonesia
    THIS ECU NOT SO EASY..
    I WAS SEND YOU PM ..
  16. #14
    bram380's Avatar
    ---no ads---
  17. #15
    darwins's Avatar
    UK
    Hi Bram
    How sure is this?
    I ask because someone else has given me an ISN different to yours.
    Thank you very much for this which ever way it goes
    Darwins
