Results 1 to 4 of 4
    Nov 2010
    Default BMW 530D E60 218PS ECM Driver or Maps location
    Hi!!
    I'm starting to tune my own cars and I would like to start with my BMW 530D. I have winols and ECM2001. I cannot find a driver that suits this car.
    I'm still not confortable searching and recognizing the maps in Winols. I would appreciate that someone could give me the addresses from the maps for it.
    I know that someone will tell to go to a local tuner but I'm in South Africa and there is no local tuner that can touch this car.
    Here's the original.
    Thanks in advance
    Sergio
    DK Veteran ZIZZOU's Avatar
    Dec 2011
    your dump is bad read
    try to reread again for best result
    bmw320d's Avatar
    you can use the ecm driver B224_886.drv
    Nov 2010
    Quote Originally Posted by ZIZZOU View Post
    I've read it with MPPS V12. It was the first time I read something with it. I have also the KWP2000+ but doesn't work with EDC16C31. I will connect a battery charger to have more than 14v and read it again.
