Ford Probe GT V6 2.5 tuning
Results 1 to 7 of 7
    Above sea-level
    44
    Downloads
    18
    Uploads
    Default Ford Probe GT V6 2.5 tuning
    Does someone have a tuning file for a Ford probe GT V6 2.5L from 1993?
    Ecu is DENSO: EGI KL07 18 881D.
    Eprom 27C256 079753-1606.
    I have attached the ori file. I have loaded the file in winols, but could not find a checksum or proper maps.
    DK Veteran ZIZZOU's Avatar
    Dec 2011
    19
    Downloads
    4
    Uploads
    bad dump m8
    Above sea-level
    44
    Downloads
    18
    Uploads
    I thought the same, but have read it with 3 programmers and all give the same read file and when I copy the content to another 27c256 and install it in the ecu it just works fine!
    247
    Downloads
    30
    Uploads
    See in 2d, your file is correct, and proper maps there are.
    Regards.
    247
    Downloads
    30
    Uploads
    A little help.
    Pass in PM.
    46
    Downloads
    26
    Uploads
    5
    i could do that for you, i own an 89 ford probe.
    you should buy a new blank eprom, not eeprom, and reprogram that one,
    Above sea-level
    44
    Downloads
    18
    Uploads
    ori read file was fine and this ecu just does not have any checksum. Maps changed, eprom programmed + installed and the car runs fine!
