Page 3 of 25 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 364
  1. #31
    V.I.P. Member benny/9's Avatar
    Nov 2008
    north west uk
    Default underworld 1.61 16/2/09
    underworld 1.61 tested working
    canal+nordic on 1w and digialb on 16e fixed
    ?Version 2.3 ONLY? Conax: Canaal Digital Nordic - Thor 3/5 0.8W>>>ok
    ?Version 2.3 ONLY? Conax: DigitAlb - Eutelsat W2 16.E)>>>>>>>>>>ok
    ?All Vers.? Irdeto2: Free X TV - Hotbird 6/7A/8 13E>>>>>>>>>>>>>ok
    ?Version 2.3 ONLY? Irdeto2: M*T on 9E>>>>>>>>>>>>>>>>>>>>>>ok
    Conax: Kabelkiosk -on 9E and 8W are down waiting a bib file>>>>>>DOWN
    there are also in the zipped folder that you load after the u/w dup cam file
    there is a digialb data bin file and a s2_nl bin file
    for digi-tv and the nl chns on astra 19e
    the data bin only works on underworld 1.61 file
    Please Read Carefully!
    No Sky UK NDS Videoguard Hacking Discussions.
    Viewing Pay TV without a valid subscription is illegal
    the files available are kept for experimental & educational purpose only
    original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,
  2. #32
    Default Underworld 1.61 & Data file
    I have loaded both the DUP and data files and can open Digialb but cannot open Digi TV or NL channels on 19e. I have a Humax 5400. Any suggestions.
  3. #33
    Default Underworld 1.61 and data file.
    I have played around with the Diablo. I have formated and reloaded and now I am not able to open any channel and get a smartcard message telling me to please insert my card. Any help would be welcome.
  4. #34
    Quote Originally Posted by mulvihc View Post
    You must format twice load underworld 1.61 and add the NEW bin file.
    you have to go into the cams menu, enter the configuration sub menu and then turn Emulators to ON.
    Are you using the latest Cas Studio 8.6c?
  5. #35
    Default Humax 5400 problem.
    Thanks Bassethound. 1 further question before I start. For the 161 files posted above I cannot open them with WinZip. I keep getting message "Cannot open file: it does not appear to be a valid download". I am using the wrong WinZip file to open ?
  6. #36
    In the Cam File System I see the EMU menu. How do I turn it on. When I left or right click it opens 2 files TABLES and NAGRA. I do not see the option to turn it on. Please help.
  7. #37
    Nov 2008
    north west uk
    after you have loaded the 1.61 dup file and then the data file
    put the cam in the receiver slot and turn on
    press menu and>go to common interface and you will
    see the file name ie:underworld 1.61 highlight it
    and click>ok on the next panel go to [4] configuration
    and click>ok on the next panel set the configuration
    to the following settings useing you vol and chn buttons
    on your remote to scroll and change the menu's
    [1] language [english]
    [2] caids file [caids]
    [3] PMT - [on]
    [4] emulators [on]
    [5] N2 AU [off]
    [6] Emu priority [1:emu-2:cards]
    [7] fixed cw [on]
    [8] Smartcard mess [show never]
    [9] adminstrator menu [ do not change anything in this ]
    after you have set the cam config to the above settings
    exit the menu and turn the receiver off and on again to
    lock the settings in the cam menu,now the chns will open.
    and you dont have to format the cam everytime you load
    a new file the files overwrite one anouther
    if you do format the cam you loose all your cam settings
    and then you need to do the above again
  8. #38
    Nov 2008
    north west uk
    i take it your channels are now open?
    here you go i will post a bit extra for you to test
    thats if the matron allows you to view these channels
  9. #39
    Nov 2008
    north west uk
    Default New data bin for Diablo and Qbox 18/02/09
    Update : TSA/SCT (9?E/13?E)
    In order to make the channels open
    before to select a bouquet channel
    you have to select a channel thats free to air
  10. #40
    Nov 2008
    north west uk
    New data bin for Diablo and Qbox 18/02/09 (Second Update today)
    New data bin for Diablo cam and Qbox
    whats new on this file
    Updated KabelKiosk on 8w and 9e plus M*t 9E
  11. #41
    Sep 2008
    Default digitv 1w
    hi is digitv open on 1w????
  12. #42
    Nov 2008
    north west uk
    Quote Originally Posted by khan View Post
    yes turn the n2 A/U off in the configuration on the cam
  13. #43
    Nov 2008
    north west uk
    Default new underworld 1.62 27/2/09
    What's New??
    Fixed all the emulators
    XclusiVe E M Us
    ?Version 2.3 ONLY? Irdeto2: MCT (9.0?E)
    ?Version 2.3 ONLY? Conax: Canaal Digital Nordic - Thor 3/5 (0.8?W)
    ?Version 2.3 ONLY? Conax: DigitAlb - Eutelsat W2 (16.0?E)
  14. #44
    Nov 2008
    north west uk
    Default Re: UnderWorld DATA.BIN 28/2/09
    UnderWorld 162 DATA.BIN + S2_NL.BIN missing in last firmware
    UnderWorld 162 DATA.BIN works only under Underworld 1.62
    Exclusive E M Us Fixed
    ?Version 2.3 ONLY? Irdeto2: SEX/SCT S1-3 Eurobird 9A (9?E) & Hotbird 8 (13?E)
    ?Version 2.3 ONLY? Conax: Digit Alb - Eutelsat W2 (16?E)
    ?Version 2.3 ONLY? Conax: MTV Unlimited - Astra 1M (19.2?E)
    ?Version 2.3 ONLY? Conax: DaVinci Learning - Sirius 4 (4.8?E)
    ?Version 2.3 ONLY? Conax: SSN TV - SuperSports Network - Atlantic Bird 1 (12.5?W)
  15. #45
    dont know what im doing wrong but i cant get the diablo cas3 to see these files. Also get an unexpected end of archive message if i try to extract them. Is there anything I am doing wrong... do I need to load anything else first.
    Ok now solved, had to use firefox to download....
