i have a bike honda transalp and i have one damage key.can anyone help me to immo off dump is 93c46
n599fbm (22nd March, 2014)
Don't think u can by dump
no just make new keys
i have already new key and tag key tool from abritus
i read the eprom and i put in the tag the eprom and i push prepare key.after it make me a new dump and i write it in the ecu but the bike can not start.the lamp always is on.can somebody check the 2 eeproms to see if is all ok?key is PCF7936
most of the time when it wont start is damage to ecu when removing eeprom check all around it may ook ok but try moving it. it may be lose
i check it all ok but bike not start
i do not have the red key to programm it
i have only one which is not work
if somebody can make virgin and put a new pcf7936 transporder can programm it?
read the transponder id using the tag key tool and post it here.
when the key is new i could read it with tag key tool.
when i programm it after i can not raed it
tag key said can not raed eeror and after i put save and it save me this
do you mean this?
tell me details
hi there,
this bike not have red key.
you need only a new key with crypto mode.
put in eeprom all address 000000 and then fit it
back in ecu, turn it for 30sec. and you take the
id.
john
i do not undrstand what do you mean
must i read the eprom and must make all adress 000000
and after i read the id?what is id?
the key which i programm is off and i must buy new?
when i do all these put new key and bike start?
best regarts
no not like this it should be like this form 45 df ae e1
u can read this id using tag key tool by putting the ttransponder in the coil and read the transponder
i can not read key with tag key
when it is new i can read it but when i programm it into the dump after i can not read it
I have had this problem before, the abritus tag tool software is crap its very hit and miss with what works and doesnt , thats why i have that and tmpro .
i will give u a virgin dump u should program it to the dump and use a new pcf7936 chip and switch the ignition with it for 5 sec and close after that and it will be programmed automaticly
but this file is on my laptop pls wait me for next hours
many thanks my friend
i am waiting your dump
best regarts
