Page 1 of 2 12 LastLast
Results 1 to 15 of 23
    Nov 2008
    Default New sim2 ssl 84 for dm800(sim201 and sim210 cards)
    Sim2 released new sim2 second stage bootloader for dm800hd within the plan of continuous support for all sim products
    The new sim2 ssl 84 enables users to use original images with genuine drivers without modification on all types of sim2 dm800 boxes
    Also sim2 annouced that the new sim2 ssl 84 supports both sim2 card types for dm800hd(sim201 and sim201) and this proved all what said about stopping support for sim201 cards are totally wrong.
    Although the new ssl gives complete solution for sim2 dm800hd but there are some minor issues not resolved yet such webinterface ,wlan and software managers,however these issue could be fixed easily with available patches.
    also expected problems will be with few images like edg nemesis and oozoon images and in this case sim2 advice users to use already patched images.
    How to use new sim2 ssl 84
    -Flashing original images.
    1- load sim2 ssl84 to dreambox in setup mode by dreamup or internet explorer method then reboot the dreambox to setup mode again to activate the new ssl
    2- Flash the original image by dreamup or internet explorer methods
    3- without rebooting the dreambox flash again the sim2 ssl84 immediatley
    4-reboot the dreambox .
    -Flashing already patched images with sim2 ssl84
    just flash the image with dreamup or internet explorer method without loading sim2 ssl84 whatever the current ssl version loaded to dreambox
    -Updating already flashed image with sim2 ssl84
    we do not advice to update images in normal cases but for accidental updating we advice installation of new sim2 ssl 84.ipk before restrating the dreambox after finihsing update process
    for multiboot backup and osd flash image backup better to use sim2barryallen 4 and TSFlashbackup 4 which be available as soon as possible
    sim2 ssl 84 dm800hd should be used with the specified sim2 model,sim2 neither me are not responisble for any damage could occur from improper use.
    download
  2. The Following 5 Users Say Thank You to mfaraj57 For This Useful Post:
    liomwalledy (25th August, 2013), pantelastic (8th September, 2013), vassosk (2nd February, 2014)
  3. #2
    Jul 2011
    ... just to be 100% sure: I have DM800HD PVR (clone) with SSL82; I can use/upgrade to SSL84?
    Thank you in advance!!!
    Nov 2008
    Quote Originally Posted by bobdeville View Post
    if it is sim2 (sim201 or sim210 cards),yes you can
    Aug 2008
    Hi i have openpli 2.1 on dm800se and dm800pro, i cant back image up with TSFlashbackup 4 would i be able to back them up ?
  6. #5
    Jul 2011
    thank you for reply.
    Yes, my clone is sim 201, SSL 82, model DM800HD PVR.
    The only thing that I'm not sure that I really understand is the point 1), from how to use new sim2 ssl 84, how exactly to load the new SSL84 onto my SSL82 box.
    Which one of files should be used in step 1), sim201_ssl84.bin or sim201_ssl84.nfi ?
    I want to use an original image.
    Best regards.
    Bob
  7. #6
    Apr 2011
    i have the same question as bobdeville. im on ssl 82 using newengima 2. i noticed that newengima for ssl84 is out so how do i upgrade to that.
    2. could you tell me whats the difference its going to make if upgrade thanks in advance guyz
  8. #7
    Nov 2008
    Quote Originally Posted by lombard View Post
    difficult to backup openpli with any tool due to different structure,the only way to use it in multiboot and backup with barry allen or satisfy by save settings if used in flash
  9. #8
    Nov 2008
    if you have sim2 image with new ssl84 then flash it normally by internet explorer method and the bootloader will be upgraded to ss84
    if you want to flash original image follow the procedure in first post and use nfi file for flashing
  10. #9
    Jul 2011
    Quote Originally Posted by mfaraj57 View Post
    Can I upgrade my box to SSL84, via browser, and let the actual image I use? - will be some improvements?
  11. #10
    Nov 2008
    you can upgrade to sim2 ssl84 by browser or by installing sim2-ssl84.ipk through the image(TSpanel-addons-sim2 addons-sim2-secondstage)
    preferable to use ssl84 with latest original driver to notice difference and improvement
  12. #11
    Jul 2011
    Confirm: the update to SSL84, worked like a charm (made thru explorer) !!! Great job!!!
    If I will flash my box with latest original firmware, "release-DM800-3.2.0", before reboot that SSL84 must be flashed again?
    That image (release-DM800-3.2.0) is a good/stable one or you recomend another one?
    All I want is to work: cccam213/sbox0047 combination.
    Millions of thanks !!!
    Bob
  13. #12
    Nov 2008
    Bob
    release dm800 3.2.0 has no emu manager to run cccam213 or other cams
    release dm800 3.2.0 has different,new system and closed enigma and contain new protection against clones so mostly new sim2 ssl84 will not solve the protection of this image
    we have to wait images from other teams after dmm closed the c++ enigma source against clones and image teams
  14. #13
    Aug 2011
    I also have the same question as bobdeville had , and i also read all posts of this threat.
    I have DM800HD pvr with Sim 2.01 !!
    Its better to use SSL84 ?
  15. #14
    DK Veteran freck's Avatar
    Jul 2008
    Dark side of the Moon
    Same thing over and over guys.....if its not broke dont fix it....or else you WILL break it and cant fix it.
    If your not 100% sure on what your doing just chillax and wait for more info or even a sticky to emerge.
    Freck
  16. #15
    Nov 2008
    Quote Originally Posted by fahimjan View Post
    no harmful effect from ssl84 if used properly
    but as advice do not update the current image with new ssl84
    better to use image with ssl84 built in
  17. The Following User Says Thank You to mfaraj57 For This Useful Post:
