Results 1 to 4 of 4
    Feb 2012
    Default Which Ccam cfg file ? I have 2 ???
    OK most tutorials tell you... to edit you Cccam config file you open DCC and goto in the var folder then etc folder thats fine and I understand. I found my cnfg file Cccam 2.14 there and edited it.
    but I acidentally clicked on var-init folder there second time and found a Ccam 2.1.1 config file in there ????
    Do you just ingore that file or delete it does it need to be there ?
    pretty confusing that you have two Cccam files ?
    Jul 2008
    if it aint broke dont fix it, i guess
    Old Git PaphosAL's Avatar
    Mar 2008
    /var_init is the 'Factory Reset' source folder in the read-only SquashFS partition.
    AFAIK, the /var/etc/CCcam.cfg syntax is the same no matter which version of CCcam is in use.
    Cheers- AL
    V.I.P. Member haribo's Avatar
    Jun 2008
    in my car
    as ^^^ Al said above.
    you cant delete that file in var_init probably
    it means cccam was is in your image by default . or at least the config for it was.
