Results 1 to 15 of 17
    Member flterence's Avatar
    Default MERCEDES BENZ XENTRY 01/2012 Simulation Error Problem
    Dear All
    I installed the DAS / XENTRY 01/2012 Complete ,
    DAS Simulation and Connect to cars work fine , all Ok ,
    XENTRY Connect to cars ( W204,W212,W207) same working fine Ok too ,
    But Problem on XENTRY Simulation !
    Will hold Freezes to the First Step , can't run to 2 to 15 step , just wait and hold on 1 step .. when i run Simulation on W204,W212 and W207 , But not any error Display ,
    which friend know this is what problem on ?
    Please help me solve this Problem,
    Thank you for your mind and Support !
    Best Regards
    confirm it. on real c4 there is no problem with simulation.
    Default Sim
    Tell what you have made with asam3d.ini!!!
    Oct 2011
    Default try this
    Get push THANKS on right side button . . . . and add
    I still not solved the XENTRY Sim Problem,
    Quote Originally Posted by sunduk112 View Post
    You must mean this one solves the DAS simulation issue (like seems to appear after AddOns)?
    The original issue was about Xentry simulation freezing.
    DK Veteran cocoh's Avatar
    Jun 2009
    brother.. its another trick...
    Oct 2011
    ups sorry
    Jan 2011
    Reinstall XENTRY
    apply all addons and xentry sim will be ok
    Dear All
    i solved the XENTRY Sim Problem,
    Thank you for all support and mind
    Now just the CEASAR TEST Can't Run
    Best Regards All
    Quote Originally Posted by weryo View Post
    No need to confirm what weryo says (what ever he says, it is always perfectly correct) but since I mentioned above that the issue seemed to appear after AddOns were installed, I think it is fair to say that at the time this thread was created, all AdOnns were not sufficient but since then a new AddOn was released and that seemed to fix the Xentry simulation issue (at least did for my setup).
  13. #13
    Default Xentry sim
    Yes he is a StarDiagnosis Hero but not the Guy who knows all!
    I know this Problem!!! All Addons installed and Xentry Sim makes only one step in application.
    It must be fixed by other way, not with Addons and not with asam3d.ini
    Cheers Shacky
  14. #14
    We dont have to know all,but enough is just enough!
    I know another trick,without any edit that solves xentry sim,...but I am going to stay on the way teradyne fixes it,because as much fixes and tricks were shown on the forums,.as pain we could feel in future!
    Good luck!
  15. #15
    Apr 2012
    Hi. just installed xentry 03.2012, it works fine, but there is no SIMULATOR. it has not installed. How could this happen?
