Results 1 to 5 of 5
Hybrid View
    Top Poster infobadr's Avatar
    Nov 2008
    ALGERIA
    Default xprog adapter TMS 374
    can someone help me I bought xprog clon and get this TMS 374 ON board programming adapter Rev A 2005.05.11
    P/C 1-002-0010 TO reade s103238R31403PQQ FOR fenix 5 (renault)
    hi,I have problem to read it
    i need to know the lift pin on board programming adapter Rev A 2005.05.11
    problem ( the adaptor as show in attached
    Nov 2008
    ALGERIA
    SORRY THE ATTACH FIL IN RAR FIL
    Nov 2008
    ALGERIA
    PLS ANY FREINDS HELP MY
    THANKS
    Dec 2009
    If I understand your problem correctly!. The adapter board was cloned badly, the foot print is not perfectly aligned to the chip pins. From my photos forget the four pads on the left side, completely removing them off with a sharp knife. Now without needing to care the alignment on the left if you try to put the chip on the board again, will see that the chip pins align more perfectly onto the remaining three sides. To fix the problem of missing the four pads now you may find something from the second image. I made twin tiny holes on PCB for each pin connection, the holes are for to fix the tiny wires firmly to the PCB for repeated usages. Use the same wires cross soldering from these points to the correct MCU pins on each use. You may use some other method instead anyway. Hope this helps.
  5. The Following 7 Users Say Thank You to Zmann For This Useful Post:
    acmotor (22nd June, 2018), elephantul (29th January, 2017), mek007 (23rd October, 2016), mustafa06 (30th July, 2020), rapkopat (27th January, 2016), waleedfarag (21st January, 2019), xseva (5th February, 2022)
  6. #5
    Nov 2008
    ALGERIA
    BIG THANKS FREND ZMANN
    THANKS
