Use a null modem cable.
This box doesnt have a serial port
you need a a/b mini usb cable the same as used
to connect a digital camera to the computer and
use a dreamup panel and use the last known ip for the box
i got a long cable from maplins also take a look at this thread
http://www.digital-kaos.co.uk/forums...ni-usb-113941/
also if a clone box you need a patched dreamup version
Please Read Carefully!
No Sky UK NDS Videoguard Hacking Discussions.
Viewing Pay TV without a valid subscription is illegal
the files available are kept for experimental & educational purpose only
original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,
I think that if there is no jtag then the box is dead
Using mini USB and ethernet cable , I can see ip but dreamup wont recognise the box. It prepares the connection and then says now turn on your dreambox, but when I do nothing happens
What bothers me is I get no light at the front of the box - nothing
but as I said there is activity lights at the ethernet port nad the red lights inside the box and the fan spins, strange, anyone else got this?
I had a similar problem with dream up not recognising my box , so I tried about 4 different versions of dream up - old ones new ones and latest ones and eventually one of them worked. Oh and dm500 hd doesn't have an led display just green or red light ,the ip comes up on your tv screen.
Thanks for reply
Ive tried dreamup 1321,1334, 1335, and a patched one by natas and forhike with no joy
I managed to get an ip from the box
(hit and miss, sometimes recognised but not always
- but dreamup doesnt recognise the box when I power it up)
here is the telnet readout
* NewNigma2 please wait ... *
* the next step is done *
OpenDreambox
dm500hd login:
root
Password:
-------------------- < Script > ----------------------------
root@dm500hd:~#
df -m; echo ">>> DONE <<<";
Filesystem 1M-blocks Used Available Use% Mounted on
/dev/root 60 41 19 68% /
none 71 0 71 0% /dev
shm 71 0 71 0% /dev/shm
/dev/mtdblock2 4 2 1 61% /boot
tmpfs 71 0 71 0% /var
tmpfs 71 0 71 0% /tmp
>>> DONE <<<
root@dm500hd:~#
c
lear
[H[Jroot@dm500hd:~#
Is there a way to flash the box using telnet?
Thanks for any help
There is a post on here by "benny/9 " 'Dm500hd dream up problem?!' its in dm500hd section ,Have a look at that post and see if it's any help to you. Also there is a program called flash wizard some people use for flashing ,I've never used it myself so I can't comment about it.
Hi its also post #4 in this thread
I started off trying to flash with dreamup using the miniusb
Windows 7 sees the box and installs driver
I can put in a an IP and dreamup says now power up your dreambox when I click connect, but when I power up....nothing happens
Ive tried dreamup 1324, 1334 1335 and natas and forhike
The only response Ive got is using telnet, and I can see the folders using ftp
so I think it should be possible to flash the box somehow
What do you get when you hold the button on the front of the dreambox and then power on from the wall ?
Its the same whether I press the button or not
First
dm500hd newenigma logo and please wait message appears
then
dm500hd newenigma logo meassage changes to booting...
then
dm500hd newenigma logo message changes to starting..
then a message box appears "service unavailable check configuration"
this times out and the box hangs with
dm500hd newenigma logo starting...
Nothing happens when I press remote.
What is supposed to happen when I press the button on the front of the box?
You hold the button on the front of your box when it's powered off from the wall , keep holding and power on from the wall ,after a few seconds the details of your box including ip address should come up on your tv screen and that is your box in flashing mode via ethernet .
Did you found a solution for your problem?
I am having some problems uploading a new firmware.
