Results 1 to 8 of 8
Thread: blur, ghosting
    Nov 2008
    Default blur, ghosting with images
    Just got in opened my new openmedia box, plugged it in and the text has a blur/ghosting surrounding all of the text.
    checked scart run it through rca cables(worse)
    seems quite bad to me,
    how do these things compare to a stand alone DM500 picture wise?
    Trying another image right now...
    Has anyone else seen this problem before?
    Nov 2008
    Above is the ghosting from openmedia.
    The bottom image is from a DM500
    DK Veteran portbhoy's Avatar
    Sep 2008
    I have 2 of these boxes now and have no problems with them, I assume you've checked your AV settings?
    Nov 2008
    not much to check really, on RGB, PAL,16:9
    checked with a 1.99 scart ribbon cable
    checked with a ?40 full RGB IXOS Cable
    Tried Different TV
    Dreambox 500 using exactly same image as openmedia is spot on.
    Tried using RCA cables (actually looks worse)
    V.I.P. Member westkill's Avatar
    May 2008
    did you try a different image and try on different tv to rule there is a problem with the box
    dm800-s=1.1 m triax motorised dish=titanium twin lnb
    DIGITAL KAOS BEST SITE ON THE NET
    please use the thanks button if someone has helped
    Nov 2008
    sure did,
    I have effectively tried 4 images as the cable and satelite images are seperate.
    Sep 2008
    I got my box from Max G from his online store but i went to collect it in person.(you can find him on the forum)
    He said that all these box's suffer from this problem but he offers a free mod to his customers and replaced a resistor or capacitor inside the machine to fix the text blur problem.
    I would strongly suggest returning your box to the seller and ask them to either fix the fault or refund you.
    Apr 2008
    only the first initial small batch suffered from this problem, this has now been rectified and all units that have been sold from october onwards are from the new batch and there should be no problems.
