After the accident bmw x5 e70 not run. The fuel pump does not provide. How does it run? I know I have to look for the module responsible for it.
think u have to clear crash codes in ecu l would think
Cleared codes somewhere is a module responsible for the pump. I have in ecu error something like , Sim: no message (B) from satelite, a-pillar left
have u looked in airbag codes or immobilizer menu
airbag codes
if its been in a crash it will activate bags and immobilize fuel
if it does not work like
http://www.digital-kaos.co.uk/forums...cation-174388/
no idea .,, strange it has been in crash and now will not start
I found EKP
hi all , also check the battery post , you will see two thin wires to what loook like a log fuse , this could explode in the crash and cut connection .
cj
In ekps i have errors 6295 no control current
Here you go . After crash dde shut off pump...
Safety functions - WDS
........ but how to run the pump
YES clear crash data
AS far as the sattelites are concerned. Digging thrue DIS57 what sattelites means,,,,,,,,( a ****ing crash sensor) OR (airbag module which are 4 inside car) but noone explains a term sattelite exactly...
SO a-pillar left means (translated into VAG terms) crash sensor driver side (a-pillar) the place where the drivers door is bolten on down low.
I hate DIS
