Results 1 to 9 of 9
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    Default Suzuki Wagon R Pin Code
    Hi ...
    Having problem with Suzuki Wagon R 2002, ECU Denso Immo Box Siemens TMS320 with Opel.
    I read files Immo Box, but the code that comes out has a letter! With Diagnosis Tool Box Enter Immo, Opel as Agila, but to program the key, I used four numbers and no letter!!
    Do you have solution to the problem? I tried with sbb!
    attach files Immo Box
    keygargoil's Avatar
    try pin 1204
    try 0895 this i use with tech 2
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    no .. 1204 -- 0895 ... use Texa
    koncimobil's Avatar
    Sep 2011
    soxxi
    pin code:
    26 B1
    richard27's Avatar
    Aug 2011
    Pin Kod: 26B1
    ​information sharing
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    I friends, I have tested. The Pin Code does not exist! I take another box of real estate on a Suzuki! TMS read, passed in AD900 and Pin code is always the same 26B1 ! Talked to service suzuki, told me that there not existe pin code, ECU and Immo Box, you must align with the original diagnostic tool! I tried with SBB and program keys used, but is not aligned with the engine ECU!
    Nov 2010
    dorset england
    Default suzuki wagon r pin code GM LS 24 445 097 IMMO 2
    have programmed new keys in using opcom and live data shows new keys are valid but immobiliser is still active
    DK Veteran bobbik's Avatar
    EUROPE
    guys, how did you input "B " in op-com ? Mine op-com rejected letters...
